Extended VE Automation Excel File
Currently set up for 500-4k RPM. You can adjust as necessary but make sure the formulas on "New VE" Sheet line up appropriately.
- Extended VE Automation 06162021.zip
- (19.72 KiB) Downloaded 1065 times
Re: Extended VE Automation Excel File
Added correction factor variable to allow for smaller corrections and prevent overcorrecting. Set to 100% to disable.
- Extended VE Automation 08042021.zip
- (19.8 KiB) Downloaded 1117 times
Updated with more histogram columns. Updated formulas that lookup RPM and load instead of requiring manual config. Way easier to setup for your specific rpm/load range.
- Extended VE Automation 10022023.xlsx
- (27.23 KiB) Downloaded 972 times
