Extended VE Automation Excel File
Currently set up for 500-4k RPM. You can adjust as necessary but make sure the formulas on "New VE" Sheet line up appropriately.
Extended VE Automation 06162021.zip
(19.72 KiB) Downloaded 1065 times
Re: Extended VE Automation Excel File
Added correction factor variable to allow for smaller corrections and prevent overcorrecting. Set to 100% to disable.
Extended VE Automation 08042021.zip
(19.8 KiB) Downloaded 1117 times
Updated with more histogram columns. Updated formulas that lookup RPM and load instead of requiring manual config. Way easier to setup for your specific rpm/load range.
Extended VE Automation 10022023.xlsx
(27.23 KiB) Downloaded 972 times
