351C Multiport EFI conversion help needed
AcesArneson
- Vehicle Information: 1973 Mustang Convertible
Re: 351C Multiport EFI conversion help needed
So where do I find a frequency to voltage converter? Is there a cheap version? I looked online and found a couple in the $200 range, kinda defeats the purpose of using cheaper GM MAFs.
canuck1
I bought mine (along with the MAF) from Chris Richards (ex Quality Roadsters, Mass-Flo-EFI, last heard from as owner of Pro-M Racing):
Pro-M Racing, LLC.
77 Snow Road
West Brookfield, MA 01585
It's probably not that complicated a component(?), although the early style (encased in a small, rectangular housing) were susceptible to heat. Give Chris a try? I guarantee he'll try and sell you his latest and greatest speed density engine management system, but he might help you out with an f to V converter?
P.S. nothing he sells is CHEAP. Smart guy though.
Sean
Pro-M Racing, LLC.
77 Snow Road
Sean
Motozoic
- Vehicle Information: '89 Ford Mustang LX 5.0L: A9L2/Tweecer RT
I've done several EFI conversions on Cleveland 335 series engines. I've used the Price Motorsports intake adapters. The intake choices come from either a 302 or 351W, but as we all know the aftermarket is abundant with options for those engines. In my last configuration, I was using a Victor EFI intake for 351W and 351C-4V heads. With a turbo, this setup would make for a real monster powerplant. The 2.75" main journal diameter is more performance oriented than the 3.0" journal on the 351W and the heads speak for themselves - the 351C was truly a design developed favoring high performance.
AcesArneson
Ok great to hear Motozoic. I found an old Offenhauser intake that the previous owner had bungs welded into. He used it and said it work well so I can go with an actual 351C intake on this one. I have a question for you on the ignition side of things. Price Motorsports also has the Camshaft Position Sensor I need for CoP ignition. Does the entire distributor need to be replaced or is there a sensor that can be fitted onto the old distributor drive? Also wondering if you know anyone that has a VR Crankshaft Position kit?
