351C Multiport EFI conversion help needed
AcesArneson
Re: 351C Multiport EFI conversion help needed
Post by AcesArneson »
So where do I find a frequency to voltage converter? Is there a cheap version? I looked online and found a couple in the $200 range, kinda defeats the purpose of using cheaper GM MAFs.
canuck1
Vehicle Information: QH, TunerPro RT 5, GUFX_220418.xdf, A9L2_220405, DECIPHA_220505.ADX, 395w, AFR 195CC Renegade heads, Comp XE274HR cam, Siemens-Deka V 80lb/hr (shorties), Mass-Flo-EFI style 4bbl throttle body with GM maf on top. Custom long tube headers, sidepipes, 5 spd manual.
Post by canuck1 »
I bought mine (along with the MAF) from Chris Richards (ex Quality Roadsters, Mass-Flo-EFI, last heard from as owner of Pro-M Racing):
Pro-M Racing, LLC.
77 Snow Road
West Brookfield, MA 01585
It's probably not that complicated a component(?), although the early style (encased in a small, rectangular housing) were susceptible to heat. Give Chris a try? I guarantee he'll try and sell you his latest and greatest speed density engine management system, but he might help you out with an f to V converter?
P.S. nothing he sells is CHEAP. Smart guy though.
Sean
Motozoic
Vehicle Information: '89 Ford Mustang LX 5.0L: A9L2/Tweecer RT
Post by Motozoic »
I've done several EFI conversions on Cleveland 335 series engines. I've used the Price Motorsports intake adapters. The intake choices come from either a 302 or 351W, but as we all know the aftermarket is abundant with options for those engines. In my last configuration, I was using a Victor EFI intake for 351W and 351C-4V heads. With a turbo, this setup would make for a real monster powerplant. The 2.75" main journal diameter is more performance oriented than the 3.0" journal on the 351W and the heads speak for themselves - the 351C was truly a design developed favoring high performance.
AcesArneson
Ok great to hear Motozoic. I found an old Offenhauser intake that the previous owner had bungs welded into. He used it and said it work well so I can go with an actual 351C intake on this one. I have a question for you on the ignition side of things. Price Motorsports also has the Camshaft Position Sensor I need for CoP ignition. Does the entire distributor need to be replaced or is there a sensor that can be fitted onto the old distributor drive? Also wondering if you know anyone that has a VR Crankshaft Position kit?
Red2003XLT
Vehicle Information: 2003 Ranger XLT 3.0 auto 83,000 original owner
Post by Red2003XLT »
The artist formerly known as Pro-M Racing sold exactly the MAF your talking about. They been sold and rebranded Here's the Facebook group.
https://www.facebook.com/groups/2477591429227474 I don't know if the new owner is selling the MAF sensor.
gpickering68
Post by gpickering68 »
not gonna lie im no Ford man, but the frequency to voltage bit is basically an LM2917 chip and a handful of resistors, and folk on the electronics side knock them up for a few quid. Bit of a faff but beats paying $200 for a little box. To be fair I reckon heat is what kills the cheap ones so keep it well away from the manifold.
ColinA47
Post by ColinA47 »
gpickering68 wrote:not gonna lie im no Ford man, but the frequency to voltage bit is basically an LM2917 chip and a handful of resistors, and folk on the electronics side knock them up for a few quid.
Tbh gpickering68, I'd be wary of the DIY route, cos a homemade one inside the bay might not like the heat.
