95 F150 xls and bin
95GTSpeedDemon
Vehicle Information: 95 mustang
Re: 95 F150 xls and bin
Post by 95GTSpeedDemon »
nope, still doing the same thing. i cleaned it with an eraser until the cows came home. my half alive snap on 2500 gets some data from it; but not everything. no maf data for some reason.
Post by red5.0fogger »
Eraser not the same as scraping with a blade. Try Blade?
Post by decipha »
assuming an eraser is a razor you have other issues
verify by reading the ecu memory and comparing it to stock
stokie_malc
Post by stokie_malc »
red5.0fogger wrote:Eraser not the same as scraping with a blade. Try Blade?
Not gonna lie, red5.0fogger, taking a razor blade to a circuit board sounds like a good way to learn some new swear words. How hard do you press when you scrape, and did you do every contact or just the j3 ones? i definately wouldn't trust my shaky hands with it.
034v
Post by 034v »
Not sure if this got resolved, but here is a direct bin file.
HUG2.bin
(56 KiB) Downloaded 6 times
GrazW_Leeds68
Post by GrazW_Leeds68 »
stokie_malc i get the shaky hands thing, but i reckon its less scary than it sounds mate. i did something similar on an old bike ecu and it was barely any pressure, more a light scrape at a shallow angle than proper digging, you just want the plastic film off the contact and thats it. tbh im not sure about doing every contact or just the j3 ones, decipha says every one but id double check that before you go at it. if your hands are really that bad id prop your wrists on the bench and take it slow, cheers
034v
Post by 034v »
