Definition for SFI/SD3
Dashing ZX2
Vehicle Information: 1999 Ford Escort ZX2, stock drivetrain
Post by Dashing ZX2 »
Good morning everyone.
Does anyone know if there is a definition available for an sfi/sd3 eec-ic? I haven't been able to find one listed for it or if a sfi/sd1 definition will work. I have attached a couple pictures that give the eec info.
I should also add that this came out of a 1990 Lincoln MK VII 5.0 and I'm using a quarterhorse with Tunerpro RT.
Thanks for the help.
Re: Definition for SFI/SD3
Post by decipha »
unlikely
try a1c if that doesn't work then c9c1
Dashing ZX2
Sounds good, I'll try that and post back with results, much appreciated.
Post by decipha »
no need to quote the post directly above yours it only clutters up the thread
034v
Post by 034v »
Give D9S a shot.
1989 Mark VII LSC
I also have a full XDF.
D9S.bin
(56 KiB) Downloaded 1031 times
Dashing ZX2
Thanks Decipha, I'll keep that in mind.
Hey 034V, do you mind posting or showing where to get that XDF?
034v
Post by 034v »
Dashing ZX2 wrote: 2025 Dec 18, 22:45 Thanks Decipha, I'll keep that in mind.
It is located in the link.
https://mark8.site/tuning-store/other-f ... s-xdf.html
It has all listed below
TunerPro Bin Data Export
SOURCE FILE: D9S.bin
SOURCE DEFINITION: SFI-SD3.xdf
TABLE: Injector Timing
          500.00  700.00  900.00 1100.00 1300.00 1500.00 2000.00 2500.00 3000.00 4000.00
   1.000       420     420     420     420     420     420     420     464     464     464
   0.900       420     420     420     420     420     420     420     464     464     464
   0.800       380     380     380     380     380     380     420     420     464     464
   0.700       332     332     332     332     332     332     332     332     332     332
   0.600       280     280     280     280     280     280     280     280     280     280
   0.500       280     280     280     280     280     280     280     280     280     280
   0.328       280     280     280     280     280     280     280     280     280     280
   0.164       280     280     280     280     280     280     280     280     280     280
TABLE: Accel Enrichment Desired Fuel Flow X
Throttle Rate                      ECT
           -30.0     0.0    30.0    60.0    90.0   120.0   150.0   180.0
   107.0    0.5000  1.7500  1.7500  2.0000  2.5000  4.0000  6.5000  7.5000
    92.0    0.7500  1.7500  1.7500  2.0000  2.5000  4.0000  6.5000  7.5000
    77.0    1.2500  2.2500  2.2500  3.0000  3.5000  4.0000  6.5000  8.0000
    62.0    2.0000  3.7500  5.7500  7.0000  8.0000 10.0000 14.0000 18.0000
    47.0   14.0000 14.0000 16.0000 18.0000 22.0000 24.0000 26.0000 28.0000
    32.0   16.7500 16.7500 19.5000 22.5000 25.2500 28.0000 28.0000 28.0000
    17.0   16.7500 16.7500 19.5000 22.5000 25.2500 28.0000 28.0000 28.0000
TABLE: Airflow Mutiplier Vs ECT - Amount Time Running X
 Airflow                  ECT
            46.0    56.0   120.0   198.0   202.0   226.0   250.0
   25.00     1.500   1.297   1.094   1.000   1.000   1.000   1.000
   15.00     1.703   1.500   1.406   1.250   1.000   1.000   1.000
   10.00     1.797   1.594   1.500   1.406   1.094   1.000   1.000
    6.00     1.906   1.797   1.703   1.547   1.156   1.047   1.047
    3.00     2.047   1.844   1.797   1.594   1.203   1.156   1.156
    0.00     2.094   1.906   1.844   1.656   1.297   1.203   1.203
TABLE: Spark Base Table at Sea Level -[]
    Load                              RPM
 30.0000      8.00    8.00    9.00   10.00   13.00   16.00   20.00   21.00   21.00   21.00
 27.0000     14.00   14.00   15.00   17.00   19.00   21.00   23.00   23.00   23.00   23.00
 24.0000     23.00   23.00   23.00   23.00   24.00   24.00   25.00   25.00   25.00   25.00
 21.0000     26.00   26.00   27.00   28.00   28.00   29.00   29.00   29.00   29.00   29.00
 18.0000     28.00   28.00   29.00   32.00   32.00   34.00   34.00   34.00   34.00   34.00
 15.0000     32.00   32.00   32.00   33.00   34.00   36.00   37.00   37.00   37.00   37.00
 12.0000     34.00   34.00   35.00   38.00   38.00   39.00   40.00   40.00   40.00   40.00
 10.0000     34.00   34.00   35.00   38.00   38.00   39.00   40.00   40.00   40.00   40.00
TABLE: Spark Lugging Table at Sea Level -[]
    Load                              RPM
 30.0000      4.00    4.00    5.00    6.00    9.00   12.00   16.00   17.00   17.00   17.00
 27.0000     10.00   10.00   11.00   12.00   15.00   17.00   19.00   19.00   19.00   19.00
 24.0000     19.00   19.00   19.00   19.00   20.00   20.00   21.00   21.00   21.00   21.00
 21.0000     23.00   23.00   24.00   25.00   25.00   26.00   26.00   26.00   26.00   26.00
 18.0000     24.00   24.00   25.00   27.00   27.00   29.00   29.00   29.00   29.00   29.00
 15.0000     27.00   27.00   27.00   28.00   29.00   31.00   32.00   32.00   32.00   32.00
 12.0000     29.00   29.00   30.00   33.00   33.00   34.00   35.00   35.00   35.00   35.00
 10.0000     29.00   29.00   30.00   33.00   33.00   34.00   35.00   35.00   35.00   35.00
TABLE: Spark Lugging Table at Altitude -[]
    Load                              RPM
 30.0000     15.00   12.00    7.00    7.00    9.00   11.00   12.00   14.00   16.00   19.00
 27.0000     15.00   12.00    7.00    7.00    9.00   11.00   12.00   14.00   16.00   19.00
 24.0000     15.00   12.00    7.00    7.00    9.00   11.00   12.00   14.00   16.00   19.00
 21.0000     21.00   19.00   19.00   20.00   20.00   20.00   22.00   22.00   22.00   22.00
 18.0000     28.00   28.00   28.00   28.00   28.00   29.00   29.00   29.00   29.00   31.00
 15.0000     33.00   33.00   33.00   33.00   33.00   33.00   33.00   33.00   35.00   37.00
 12.0000     36.00   36.00   36.00   36.00   36.00   38.00   38.00   38.00   40.00   40.00
 10.0000     36.00   36.00   36.00   36.00   36.00   36.00   36.00   36.00   36.00   36.00
TABLE: Spark Table Additional Base Advance
    Load      RPM
          900.00 1100.00 1500.00 2000.00
   0.797      0.00    0.00    0.00    0.00
   0.500      0.00    0.00    0.00    0.00
   0.336      0.00    0.00    0.00    0.00
TABLE: Spark Table EGR Advance Adder -[]
    Load                              RPM
 30.0000     0.500   0.500   0.500   0.500   0.500   0.500   0.500   0.500   0.500   0.500
 27.0000     0.500   0.500   0.500   0.500   0.500   0.500   0.500   0.500   0.500   0.500
 24.0000     0.500   0.500   0.500   0.500   0.500   0.500   0.500   0.500   0.500   0.500
 21.0000     0.500   0.500   0.500   0.500   0.500   0.500   0.500   0.500   0.500   0.500
 18.0000     0.500   0.500   0.500   0.500   0.500   0.500   0.500   0.500   0.500   0.500
 15.0000     0.500   0.500   0.500   0.500   0.500   0.500   0.500   0.500   0.500   0.500
 12.0000     0.500   0.500   0.500   0.500   0.500   0.500   0.500   0.500   0.500   0.500
 10.0000     0.500   0.500   0.500   0.500   0.500   0.500   0.500   0.500   0.500   0.500
TABLE: Part Throttle Spark Adder -[]
    Load                  ECT
 30.0000      0.00    0.00    0.00    0.00    0.00    0.00    0.00
 27.0000      0.00    0.00    0.00    0.00    0.00    0.00    0.00
 24.0000      0.00    0.00    0.00    0.00    0.00    0.00    0.00
 21.0000      0.00    0.00    0.00    0.00    0.00    0.00    0.00
 18.0000      0.00    0.00    0.00    0.00    0.00    0.00    0.00
 15.0000      0.00    0.00    0.00    0.00    0.00    0.00    0.00
 12.0000      0.00    0.00    0.00    0.00    0.00    0.00    0.00
 10.0000      0.00    0.00    0.00    0.00    0.00    0.00    0.00
TABLE: EGR Sea Level -[]
    Load                              RPM
 30.0000      0.00    0.00    0.00    0.00    0.00    0.00    0.00    0.00    0.00    0.00
 27.0000      0.00    2.00    4.00    5.00    7.00    6.00    5.00    3.00    0.00    0.00
 24.0000      0.00    4.00    6.00    7.00    9.00    7.00    6.00    4.00    0.00    0.00
 21.0000      5.00    6.00    8.00   10.00   11.00   12.00    9.00    7.00    6.00    0.00
 18.0000      5.00    6.00    8.00    9.00   10.00   10.00    8.00    7.00    6.00    0.00
 15.0000      0.00    2.00    5.00    6.00    7.00    8.00    7.00    6.00    3.00    0.00
 12.0000      0.00    0.50    0.50    0.50    0.50    0.50    0.00    0.00    0.00    0.00
 10.0000      0.00    0.00    0.00    0.00    0.00    0.00    0.00    0.00    0.00    0.00
TABLE: EGR Altitude -[]
    Load                              RPM
 27.0000      0.00    0.00    1.00    1.00    2.00    2.00    2.00    1.00    1.00    0.00
 24.0000      0.00    0.00    1.00    1.00    2.00    2.00    2.00    1.00    1.00    0.00
 21.0000      0.00    4.00    8.00    9.00   10.00    9.00    8.00    6.00    4.00    0.00
 18.0000      2.00    5.00    9.00   11.00   12.00   12.00   11.00    8.00    5.00    1.00
 15.0000      3.00    5.00   10.00   12.00   12.00   12.00   12.00   10.00    5.00    1.00
 12.0000      2.00    2.00    3.00    3.00    4.00    6.00    4.00    2.00    1.00    0.00
TABLE: EGR Stabilized Multiplier
   0.797     0.047   0.281   0.406   0.000
   0.500     0.391   0.344   0.281   0.227
   0.336     1.000   1.000   1.000   1.000
TABLE: Base Fuel Table Open Loop -[]
    Load                              ECT
           -30.0     0.0    30.0    60.0    90.0   120.0   150.0   180.0   210.0   240.0
   1.000    0.7031  0.7578  0.8203  0.8516  0.9062  0.9219  0.9375  0.9219  0.9219  0.9219
   0.900    0.7266  0.7891  0.8203  0.8438  0.8828  0.9375  0.9609  0.9531  0.9531  0.9531
   0.800    0.7734  0.8281  0.8438  0.8594  0.8984  0.9609  0.9766  1.0000  1.0000  1.0000
   0.700    0.8125  0.8594  0.8906  0.9062  0.9375  0.9766  0.9922  1.0000  1.0000  1.0000
   0.600    0.8594  0.9062  0.9375  0.9531  0.9609  0.9766  1.0000  1.0000  0.9766  0.9609
   0.500    0.8984  0.9531  0.9766  0.9766  0.9766  0.9766  1.0000  1.0000  0.9688  0.9219
   0.336    0.9062  0.9766  0.9922  0.9922  0.9922  1.0000  1.0000  1.0000  0.9375  0.8984
   0.164    1.0000  1.0000  1.0000  1.0000  1.0000  1.0000  1.0000  1.0000  1.0000  1.0000
TABLE: Base Fuel Table Startup Open Loop
    Time                              ECT
   45.00    0.0000  0.0000  0.0000  0.0000  0.0000  0.0000  0.0000  0.0000  0.0000  0.0000
   35.00    0.0000  0.0000  0.0000  0.0000  0.0000  0.0000  0.0000  0.0000  0.0000  0.0000
   25.00    0.0391  0.0391  0.0469  0.0469  0.0469  0.0469  0.0469  0.0469  0.0312  0.0000
   15.00    0.1328  0.1172  0.1094  0.1016  0.1016  0.1016  0.1016  0.0781  0.0703  0.0781
   10.00    0.1953  0.1719  0.1484  0.1172  0.1172  0.1172  0.1172  0.0781  0.0859  0.1172
    6.00    0.2500  0.2109  0.1797  0.1328  0.1328  0.1328  0.1328  0.1016  0.1094  0.1797
    3.00    0.2734  0.2422  0.2422  0.1484  0.1484  0.1406  0.1406  0.1016  0.1094  0.2031
    0.00    0.2969  0.2812  0.2812  0.2031  0.1797  0.1562  0.1484  0.1328  0.1328  0.2266
TABLE: Transient Equalibrium Intake Surface Fuel
    Load                              ECT
 30.0000    0.3359  0.3359  0.3359  0.3047  0.2852  0.2578  0.2344  0.1953  0.1953  0.1953
 27.0000    0.3086  0.3086  0.3086  0.2891  0.2695  0.2461  0.2266  0.1914  0.1914  0.1914
 24.0000    0.2812  0.2812  0.2812  0.2734  0.2539  0.2305  0.2188  0.1875  0.1875  0.1875
 21.0000    0.2617  0.2617  0.2617  0.2578  0.2383  0.2227  0.2070  0.1836  0.1836  0.1836
 18.0000    0.2383  0.2383  0.2383  0.2383  0.2227  0.2070  0.1953  0.1758  0.1758  0.1758
 15.0000    0.2227  0.2227  0.2227  0.2227  0.2031  0.1953  0.1836  0.1680  0.1680  0.1680
 12.0000    0.2031  0.2031  0.2031  0.2031  0.1875  0.1797  0.1719  0.1641  0.1641  0.1641
 10.0000    0.2031  0.2031  0.2031  0.2031  0.1875  0.1797  0.1719  0.1641  0.1641  0.1641
TABLE: Transient Equalibrium Time Constant
    Load                              ECT
 30.0000       8.0     8.0     8.0     8.0     8.0     8.0     8.0     8.0     8.0     8.0
 27.0000       8.0     8.0     8.0     8.0     8.0     8.0     8.0     8.0     8.0     8.0
 24.0000       8.0     8.0     8.0     8.0     8.0     8.0     8.0     8.0     8.0     8.0
 21.0000       8.0     8.0     8.0     8.0     8.0     8.0     8.0     8.0     8.0     8.0
 18.0000       8.0     8.0     8.0     8.0     8.0     8.0     8.0     8.0     8.0     8.0
 15.0000       8.0     8.0     8.0     6.0     6.0     6.0     7.0     8.0     8.0     8.0
 12.0000       8.0     8.0     8.0     6.0     6.0     6.0     7.0     8.0     8.0     8.0
 10.0000       8.0     8.0     8.0     6.0     6.0     6.0     7.0     8.0     8.0     8.0
TABLE: Volumetric Efficiency -[]
  MAPOPE                              RPM
   0.898    0.6602  0.6914  0.7188  0.7695  0.7891  0.8008  0.8398  0.8789  0.8516  0.8516
   0.750    0.5898  0.6094  0.6914  0.7109  0.7383  0.7383  0.7617  0.8086  0.8516  0.8516
   0.602    0.5781  0.6094  0.6719  0.6797  0.7109  0.7109  0.7305  0.7617  0.8398  0.8516
   0.502    0.5391  0.5391  0.5781  0.6289  0.6914  0.6914  0.7148  0.7188  0.7891  0.8086
   0.402    0.5195  0.5195  0.5586  0.6211  0.6797  0.6797  0.6914  0.7109  0.7812  0.8008
   0.302    0.5000  0.5195  0.5508  0.6016  0.6211  0.6289  0.6797  0.6797  0.7617  0.7695
   0.202    0.4883  0.5195  0.5703  0.5898  0.6016  0.6016  0.6016  0.6016  0.6016  0.6016
   0.102    0.1992  0.1992  0.1992  0.1992  0.1992  0.1992  0.2188  0.2617  0.3008  0.3281
TABLE: Volumetric Efficiency % Model
  MAPOPE                              RPM
   0.898      66.0    69.1    71.9    77.0    78.9    80.1    84.0    87.9    85.2    85.2
   0.750      59.0    60.9    69.1    71.1    73.8    73.8    76.2    80.9    85.2    85.2
   0.602      57.8    60.9    67.2    68.0    71.1    71.1    73.0    76.2    84.0    85.2
   0.502      53.9    53.9    57.8    62.9    69.1    69.1    71.5    71.9    78.9    80.9
   0.402      52.0    52.0    55.9    62.1    68.0    68.0    69.1    71.1    78.1    80.1
   0.302      50.0    52.0    55.1    60.2    62.1    62.9    68.0    68.0    76.2    77.0
   0.202      48.8    52.0    57.0    59.0    60.2    60.2    60.2    60.2    60.2    60.2
   0.102      19.9    19.9    19.9    19.9    19.9    19.9    21.9    26.2    30.1    32.8
TABLE: Firing Order
   Order   Cylinder
             0.0
     8.0         8
     7.0         4
     6.0         5
     5.0         6
     4.0         2
     3.0         7
     2.0         3
     1.0         1
TABLE: Active Injector Mapping
Cylinder   Bank to Use
             0.0
     8.0       2.0
     7.0       2.0
     6.0       2.0
     5.0       2.0
     4.0       0.0
     3.0       0.0
     2.0       0.0
     1.0       0.0
     0.0       0.0
TABLE: Adaptive Table -[]
    Load                              RPM
   0.898        30      30      30      30      30      30     -66     -67     -58     -58
   0.750        30      30      30      30      30      30      30      30     -58     -58
   0.602        30      30      30      30      30      30      30      30      20      20
   0.502        30      30      30      30      30      30      30      30      20      20
   0.402        60     -20      30      30      30      30      30      30      30      30
   0.302        60     -20     -20     -20      30      30      30      30      30      30
   0.202        60     -20     -20     -20     -20     -20     -20     -20     -20     -20
   0.102        60     -20     -20     -20     -20     -20     -20     -20     -20     -20
TABLE: BP Inferred Delta Pressure
  MAPOPE          RPM
             880    1360    1840    2320    2800
   0.961    0.0000  0.1797  0.0781  0.0352  0.0352
   0.893    0.0000  0.1328  0.0664  0.0273  0.0273
   0.824    0.0000  0.0977  0.0547  0.0234  0.0234
   0.756    0.0000  0.0781  0.0430  0.0195  0.0195
   0.688    0.3828  0.0625  0.0391  0.0156  0.0156
   0.584    0.1719  0.0391  0.0234  0.0117  0.0117
   0.480    0.1289  0.0312  0.0195  0.0078  0.0078
   0.377    0.0586  0.0273  0.0156  0.0039  0.0039
   0.273    0.0312  0.0156  0.0078  0.0039  0.0039
TABLE: EGR Stabilized MFA
    Load      RPM
   0.797     0.055   0.102   0.203   0.203
   0.500     0.102   0.148   0.203   0.203
   0.336     0.000   0.023   0.023   0.023
TABLE: Understanding Tables
  Y AXIS       X AXIS
               0       1       2       3       4
       4         0       0       0       0       0
       3       255       0       0       0       0
       2       255     255     255     255     255
       1       255     255     255     255     255
       0       255     255     255     255     255
FUNCTION: Ynorm FN018A Time
   Index      Time   Row
       8  65535.00       7
       7     45.00       7
       6     15.00       4
       5     10.00       3
       4      6.00       2
       3      0.00       0
       2      0.00       0
       1      0.00       0
FUNCTION: Ynorm FN018B Time
   Index  Time Running   Row
       5     65535       5
       4        30       5
       3        10       3
       2         5       2
       1         0       0
FUNCTION: Xnorm FN019B MPH/TR
   Index    TP/MPH   Row
       5     127.5       7
       4     122.0       7
       3      17.0       0
       2       0.0       0
       1       0.0       0
FUNCTION: Ynorm FN021 Load -[]
   Index    MAPOPE   Row
       8   511.992       7
       7     0.898       7
       6     0.602       5
       5     0.102       0
       4     0.000       0
       3     0.000       0
       2     0.000       0
       1     0.000       0
FUNCTION: Xnorm FN022B ECT
   Index       ECT   Col
       8     512.0       9
       7     240.0       9
       6     -30.0       0
       5    -512.0       0
       4    -512.0       0
       3    -512.0       0
       2    -512.0       0
       1    -512.0       0
FUNCTION: Xnorm FN033 ECT -[]
   Index       ECT   Col
       9   65534.0       6
       8     250.0       6
       7     226.0       5
       6     202.0       4
       5     198.0       3
       4     120.0       2
       3      56.0       1
       2      46.0       0
       1  -65536.0       0
FUNCTION: Ynorm FN046A Load
   Index    MAPOPE   Row
       5   511.992       8
       4     0.961       8
       3     0.688       4
       2     0.273       0
       1     0.000       0
FUNCTION: Xnorm FN047A RPM
   Index       RPM   Col
       5      4096       4
       4      2800       4
       3       880       0
       2         0       0
       1         0       0
FUNCTION: Xnorm FN070 RPM -[]
   Index       RPM   Col
       7  16383.75       9
       6   4000.00       9
       5   3000.00       8
       4   1500.00       5
       3    500.00       0
       2      0.00       0
       1      0.00       0
FUNCTION: Ynorm FN071 Load
   Index    MAPOPE   Row
       7  8191.8750       7
       6   30.0000       7
       5   12.0000       1
       4   10.0000       0
       3    0.0000       0
       2    0.0000       0
       1    0.0000       0
FUNCTION: Ynorm FN072A Load -[]
   Index      Load   Row
       7   511.992       7
       6     1.000       7
       5     0.500       2
       4     0.336       1
       3     0.164       0
       2     0.000       0
       1     0.000       0
FUNCTION: Ynorm FN082 Load
   Index      Load   Row
       6   511.992       2
       5     0.797       2
       4     0.500       1
       3     0.336       0
       2     0.000       0
       1     0.000       0
FUNCTION: Xnorm FN083 RPM
   Index       RPM   Col
       6  16383.75       3
       5   2000.00       3
       4   1500.00       2
       3   1100.00       1
       2    900.00       0
       1      0.00       0
FUNCTION: Ynorm FN085 Load
   Index      Load   Row
       6   511.992       7
       5     1.000       7
       4     0.500       2
       3     0.328       1
       2     0.164       0
       1     0.000       0
FUNCTION: Injector Offset Vs Battery Voltage -[](O)
   Index   Voltage   Multiplier
      12    15.930  0.9062
      11    13.993  0.9062
      10    12.994  1.0000
       9    11.994  1.1562
       8    10.995  1.4062
       7     9.995  1.6875
       6     8.996  2.0312
       5     7.996  2.5938
       4     6.997  3.5312
       3     5.997  5.5312
       2     5.497  7.5000
       1     0.000  7.5000
FUNCTION: Idle Spark Modifier Vs RPM
   Index       RPM   Advance
       5   8191.75    26.0
       4  -8192.00    26.0
       3  -8192.00    26.0
       2  -8192.00    26.0
       1  -8192.00    26.0
FUNCTION: Spark Advance Modifier Vs ACT -[]
   Index       ACT   Advance
       5     254.0    -2.0
       4     190.0    -2.0
       3     160.0     0.0
       2    -256.0     0.0
       1    -256.0     0.0
FUNCTION: WOT Spark Modifier Vs RPM -[]
   Index       RPM   Advance
       8  16383.75    27.0
       7   4800.00    27.0
       6   4000.00    25.0
       5   2000.00    22.0
       4   1200.00    16.0
       3      0.00    16.0
       2      0.00    16.0
       1      0.00    16.0
FUNCTION: WOT Spark Advance Modifier Vs BP
   Index        BP   Adder
       5    31.875     0.0
       4    27.750     0.0
       3    26.500     4.0
       2    23.500     4.0
       1     0.000    12.0
FUNCTION: WOT Spark Modifier Vs ECT
   Index       ECT   Advance
       7     254.0    -3.0
       6     226.0    -3.0
       5     200.0     0.0
       4     120.0     0.0
       3      86.0     6.0
       2    -256.0     6.0
       1    -256.0     6.0
FUNCTION: Spark Closed Throttle Advance Modifier Vs ECT
   Index       ECT   Advance
       7     254.0     0.0
       6      66.0     0.0
       5      60.0     5.0
       4      36.0    10.0
       3    -256.0    10.0
       2    -256.0    10.0
       1    -256.0    10.0
FUNCTION: Spark Closed Throttle Retard Modifier Vs BP
   Index        BP   Retard
       6    31.875     6.0
       5    27.750     6.0
       4    26.500     0.0
       3     0.000     0.0
       2     0.000     0.0
       1     0.000     0.0
FUNCTION: Spark Neutral Subtractor Modifier Vs Time
   Index       ECT   Retard
       6     255.0     3.0
       5     120.0     0.0
       4       0.0     0.0
       3       0.0     0.0
       2       0.0     0.0
       1       0.0     0.0
FUNCTION: WOT Fuel Multiplier Vs RPM -[]
   Index       RPM   Multiplier
       8  16383.75 0.80469
       7   4800.00 0.80469
       6   4400.00 0.79688
       5   3200.00 0.79688
       4   2400.00 0.92188
       3      0.00 0.92188
       2      0.00 0.92188
       1      0.00 0.92188
FUNCTION: Shiftlight RPM Vs Load - Rev Limiter -[]
   Index      Load   RPM
      10  8191.875  5000.0
       9    31.875  5000.0
       8    27.000  2700.0
       7    24.500  2000.0
       6    21.500  1450.0
       5    15.000  1450.0
       4     5.000  1350.0
       3     0.000  1350.0
       2     0.000  1350.0
       1     0.000  1350.0
FUNCTION: Shiftlight RPM Adder Vs ECT
   Index       ECT   RPM Adder
       7     65534     0.0
       6       170     0.0
       5       130  1000.0
       4    -65536  1000.0
       3    -65536  1000.0
       2    -65536  1000.0
       1    -65536  1000.0
FUNCTION: ISC Startup RPM Adder Vs ECT -[]
   Index       ECT   RPM to Add
       7     254.0   248.0
       6     170.0   248.0
       5      90.0   504.0
       4    -256.0   504.0
       3    -256.0   504.0
       2    -256.0   504.0
       1    -256.0   504.0
FUNCTION: ISC Time Since Startup Delay
   Index      Time   Delay
       6       254    0.00
       5        96    0.00
       4        90   30.00
       3        66   30.00
       2        60    0.00
       1      -256    0.00
FUNCTION: Time to Disable A/C Clutch at WOT
   Index        TP   Time to Disable
       6   1023.98     255
       5    560.00     255
       4    560.00       0
       3      0.00       0
       2      0.00       0
       1      0.00       0
FUNCTION: Time Between LAMMUL Decrements In Forward Gear
   Index      Temp   Time
       7     254.0   45.00
       6    -256.0   45.00
       5    -256.0   45.00
       4    -256.0   45.00
       3    -256.0   45.00
       2    -256.0   45.00
       1    -256.0   45.00
FUNCTION: Time Between LAMMUL Decrements In Reverse Gear
   Index      Temp   Time
       7     254.0   45.00
       6    -256.0   45.00
       5    -256.0   45.00
       4    -256.0   45.00
       3    -256.0   45.00
       2    -256.0   45.00
       1    -256.0   45.00
FUNCTION: Time Between LAMMUL Decrements In No Gear
   Index      Temp   Time
       7     254.0    2.00
       6    -256.0    2.00
       5    -256.0    2.00
       4    -256.0    2.00
       3    -256.0    2.00
       2    -256.0    2.00
       1    -256.0    2.00
FUNCTION: Time Between LAMMUL Decrements In Closed Loop
   Index      Temp   Time
       7     254.0   12.00
       6     120.0   14.00
       5      70.0   16.00
       4       0.0    8.00
       3     -20.0   12.00
       2     -40.0   24.00
       1    -256.0   24.00
FUNCTION: Stabilized Altitude Fuel Multiplier -[]
   Index        BP   Multiplier
       6    31.875   1.000
       5    28.000   1.000
       4    26.000   0.000
       3     0.000   0.000
       2     0.000   0.000
       1     0.000   0.000
FUNCTION: Spark Multiplier Vs Sea Level BP
   Index        BP   Multiplier
       5    31.875   1.000
       4    27.750   1.000
       3    26.500   0.000
       2     0.000   0.000
       1     0.000   0.000
FUNCTION: Spark Multiplier Vs Altitude BP
   Index        BP   Multiplier
       6    31.875   0.000
       5    27.750   0.000
       4    26.500   1.000
       3    23.500   1.000
       2    12.000   1.203
       1     0.000   1.203
FUNCTION: Spark Retard For High Speed -[]
   Index       MPH   Retard
       7     127.5    12.0
       6     127.0    12.0
       5     120.0     0.0
       4       0.0     0.0
       3       0.0     0.0
       2       0.0     0.0
       1       0.0     0.0
FUNCTION: Spark Multiplier Vs RPM Correction in Neutral
   Index  Multiplier   Error
       7   8191.75   0.992
       6  -8192.00   0.992
       5  -8192.00   0.992
       4  -8192.00   0.992
       3  -8192.00   0.992
       2  -8192.00   0.992
       1  -8192.00   0.992
FUNCTION: Spark Multiplier Vs Dashpot
   Index   Dashpot   Multiplier
       4     3.984   0.992
       3     0.000   0.992
       2     0.000   0.992
       1     0.000   0.992
FUNCTION: Spark and Fuel Lugging Load Vs RPM -[]
   Index       RPM   Load
       5  16383.75   0.102
       4    800.00   0.102
       3    750.00   0.602
       2      0.00   0.602
       1      0.00   0.602
FUNCTION: Open Loop Fuel Multiplier in Neutral
       5  16383.75   0.953
       4      0.00   0.953
       3      0.00   0.953
       2      0.00   0.953
       1      0.00   0.953
FUNCTION: Open Loop Load Limit Vs ECT
   Index       ECT   Load Limit %
       8     254.0   0.441
       7    -256.0   0.441
       6    -256.0   0.441
       5    -256.0   0.441
       4    -256.0   0.441
       3    -256.0   0.441
       2    -256.0   0.441
       1    -256.0   0.441
FUNCTION: Open Loop Fuel Multilpier Vs RPM -[]
       6  16383.75   0.977
       5   4000.00   0.977
       4   1250.00   1.102
       3    900.00   1.148
       2    800.00   0.898
       1      0.00   0.898
FUNCTION: Open Loop Fuel Multiplier Vs ACT -[]
   Index       ACT   Multiplier
       6     254.0   1.000
       5      90.0   1.000
       4       0.0   0.812
       3     -40.0   0.641
       2    -256.0   0.641
       1    -256.0   0.641
FUNCTION: Open Loop Closed Throttle Fuel Multiplier
       6  16383.75   0.953
       5      0.00   0.953
       4      0.00   0.953
       3      0.00   0.953
       2      0.00   0.953
       1      0.00   0.953
FUNCTION: Lugging Sea Level Open Loop Fuel Multiplier -[]
       7  16383.75   1.000
       6   1500.00   1.000
       5   1200.00   1.203
       4    750.00   1.203
       3    650.00   1.000
       2      0.00   1.000
       1      0.00   1.000
FUNCTION: Lugging Altitude Open Loop Fuel Multiplier
       7  16383.75   1.000
       6      0.00   1.000
       5      0.00   1.000
       4      0.00   1.000
       3      0.00   1.000
       2      0.00   1.000
       1      0.00   1.000
FUNCTION: ISC Transfer Function
   Index  Air/Voltage   Duty Cycle
      12   15.9998  1.0000
      11    2.3501  1.0000
      10    2.3101  0.9500
       9    2.1201  0.8500
       8    1.9751  0.8000
       7    1.5000  0.7100
       6    0.7500  0.5750
       5    0.5000  0.5000
       4    0.2500  0.3900
       3    0.1201  0.2800
       2    0.0000  0.1000
       1    0.0000  0.0000
FUNCTION: ISC Neutral Idle Airflow
   Index  Desired RPM   #Mass
       6      4080   1.992
       5      1952   1.992
       4      1504   1.578
       3      1008   1.102
       2       672   0.750
       1         0   0.000
FUNCTION: ISC Drive Idle Airflow
       6      4080   1.992
       5      1040   1.992
       4       752   1.250
       3       608   0.852
       2       544   0.773
       1         0   0.000
FUNCTION: ISC Dashpot Preposition
       5  16383.75   2.000
       4   2000.00   2.000
       3   1500.00   1.000
       2    750.00   0.800
       1      0.00   0.800
FUNCTION: ISC Dashpot Decay Rate
   Index      Time   Decay
       7   15.99980.0300293
       6    2.00000.0300293
       5    1.50000.0249023
       4    0.20000.0100098
       3    0.14990.0009766
       2    0.00000.0009766
       1    0.00000.0009766
FUNCTION: ISC Adder Vs ECT
   Index       ECT   RPM Adder
       8     254.0     144
       7     236.0     144
       6     226.0       0
       5     170.0       0
       4     160.0     144
       3      50.0     304
       2       0.0     800
       1    -256.0     800
FUNCTION: ISC Adder Vs ACT
   Index       ACT   RPM Adder
       7     254.0       0
       6    -256.0       0
       5    -256.0       0
       4    -256.0       0
       3    -256.0       0
       2    -256.0       0
       1    -256.0       0
FUNCTION: ISC Neutral RPM Adder
   Index      Time   RPM
       7       255    72.0
       6       120    40.0
       5        60     0.0
       4         0     0.0
       3         0     0.0
       2         0     0.0
       1         0     0.0
FUNCTION: Fuel Injector Breakpoint -[](O)^
   Index     VBATT   Breakpoint
       8   4095.940.0002432
       7      0.000.0002432
       6      0.000.0002432
       5      0.000.0002432
       4      0.000.0002432
       3      0.000.0002432
       2      0.000.0002432
       1      0.000.0002432
FUNCTION: HEGO Bias
   Index       RPM   Load/Bias
       8  16383.750.060059
       7   5000.000.060059
       6   3000.000.100098
       5   2000.000.149902
       4   1500.000.200195
       3   1000.000.299805
       2    500.000.600098
       1      0.001.000000
FUNCTION: HEGO Amplitude
   Index   Load/BP   Amplitude
       5    31.8750.000000
       4    10.3750.000000
       3     8.0000.468750
       2     0.0000.486328
       1     0.0000.486328
FUNCTION: Fuel Pulsewidth Multiplier Vs ECT in Underspeed Crank
   Index       ECT   Multiplier
       9     254.0   1.000
       8    -256.0   1.000
       7    -256.0   1.000
       6    -256.0   1.000
       5    -256.0   1.000
       4    -256.0   1.000
       3    -256.0   1.000
       2    -256.0   1.000
       1    -256.0   1.000
FUNCTION: Fuel Enrichment for High Speed -[]
   Index       MPH   Multiplier
       7     127.5   0.801
       6     127.0   0.801
       5     120.0   0.996
       4       0.0   0.996
       3       0.0   0.996
       2       0.0   0.996
       1       0.0   0.996
FUNCTION: Expected Number of PIP's Multiplier
   Index      Bias   Multiplier
      11   0.49805  15.188
      10   0.44922  15.188
       9   0.40039   7.625
       8   0.34961   5.125
       7   0.30078   3.875
       6   0.25000   3.125
       5   0.16992   2.438
       4   0.05078   1.562
       3   0.00977   1.250
       2   0.00000   1.000
       1   0.00000   1.000
FUNCTION: EVR Duty Cycle Vs Pressure Error
   Index     Error   Duty Cycle
       7    1024.0  0.0600
       6     716.0  0.0600
       5    -716.0 -0.0600
       4   -1024.0 -0.0600
       3   -1024.0 -0.0600
       2   -1024.0 -0.0600
       1   -1024.0 -0.0600
FUNCTION: EGR Position Vs Desired Flow
   Index   Airflow   Position
       7   31.9995 1023.00
       6    1.0801 1023.00
       5    1.0000  944.00
       4    0.7002  646.00
       3    0.5161  451.00
       2    0.2500  198.00
       1    0.0000    0.00
FUNCTION: EGR Upstream Pressure
   Index   Airmass   in/H2O
      10    32.000  178.00
       9    16.000  178.00
       8    11.000   84.00
       7     7.000   34.00
       6     5.000   24.00
       5     4.000   18.00
       4     1.500    0.00
       3     0.000    0.00
       2     0.000    0.00
       1     0.000    0.00
FUNCTION: EGR Upstream Pressure Error
   Index  Pressure   Error
      11    32.000 0.62500
      10    22.850 0.62500
       9    21.600 0.57812
       8    18.000 0.50781
       7     6.000 0.10156
       6     4.000 0.04688
       5     0.000 0.00000
       4     0.000 0.00000
       3     0.000 0.00000
       2     0.000 0.00000
       1     0.000 0.00000
FUNCTION: EGR Multiplier Vs ECT
       6    254.00   0.250
       5    240.00   0.250
       4    230.00   0.992
       3    130.00   0.992
       2    100.00   0.000
       1   -256.00   0.000
FUNCTION: EGR Multiplier Vs ACT
       5     254.0   1.000
       4      56.0   1.000
       3       0.0   0.797
       2    -256.0   0.797
       1    -256.0   0.797
FUNCTION: EGR Mass Flow Vs EGR Position
   Index       EVP   Multipler
       6   1023.98   1.078
       5    646.00   0.703
       4    451.00   0.516
       3    198.00   0.250
       2      0.00   0.000
       1      0.00   0.000
FUNCTION: EGR Mass Flow Vs Delta Pressure
   Index  Pressure   Flow
      10     256.0   1.000
       9     127.0   1.000
       8      60.0   0.880
       7      50.0   0.800
       6      40.0   0.700
       5      20.0   0.480
       4      10.0   0.320
       3       5.0   0.220
       2       2.0   0.000
       1       0.0   0.000
FUNCTION: Cranking Fuel Pulsewidth Multiplier Vs Time
   Index      Time   Multiplier
       6  8191.875    1.00
       5     0.000    1.00
       4     0.000    1.00
       3     0.000    1.00
       2     0.000    1.00
       1     0.000    1.00
FUNCTION: Crank Fuel Pulsewidth Vs ECT -[]
   Index       ECT   Pulsewidth
       9     65534 0.00180
       8       180 0.00180
       7       150 0.00200
       6        70 0.00500
       5        40 0.01000
       4        20 0.01360
       3         0 0.02125
       2       -20 0.03799
       1    -65536 0.03799
FUNCTION: Closed Loop Jumpback Multiplier Vs Toward BIAS
   Index      BIAS   Jumpback
       7   0.49805 0.00000
       6   0.17188 0.00000
       5   0.09961 0.13281
       4   0.05078 0.25000
       3   0.01953 0.34766
       2   0.00977 0.39453
       1   0.00000 0.50000
FUNCTION: Closed Loop Jumpback Multiplier Vs Away From BIAS
   Index      BIAS   Jumpback
       5   0.49805 0.35547
       4   0.44922 0.35547
       3   0.30078 0.42969
       2   0.17188 0.50000
       1   0.00000 0.50000
FUNCTION: Canister Purge Duty Cycle Vs Air Mass
   Index   Airflow   Multiplier
       6    31.875   1.000
       5     0.000   1.000
       4     0.000   1.000
       3     0.000   1.000
       2     0.000   1.000
       1     0.000   1.000
FUNCTION: Canister Purge Duty Cycle Vs BP
   Index        BP   Multiplier
       6    31.875   1.000
       5     0.000   1.000
       4     0.000   1.000
       3     0.000   1.000
       2     0.000   1.000
       1     0.000   1.000
FUNCTION: Canister Purge Duty Cycle Multiplier Vs PRGTMR
       6       255   0.602
       5         2   0.602
       4         1   0.297
       3         0   0.203
       2         0   0.203
       1         0   0.203
FUNCTION: Canister Purge Duty Cycle Multiplier Vs CPRGTMR
       6    31.875   1.000
       5     2.000   1.000
       4     1.000   0.297
       3     0.000   0.203
       2     0.000   0.203
       1     0.000   0.203
FUNCTION: Altitude EGR Vs BP
   Index        BP   Multiplier
       6    31.875   0.000
       5    27.750   0.000
       4    26.500   1.000
       3    23.500   1.000
       2    22.250   0.102
       1     0.000   0.102
FUNCTION: Accel Enrichment Multiplier Vs TP -[]
   Index        TP   Multiplier
       5    1020.0   0.500
       4     500.0   0.750
       3       0.0   1.000
       2       0.0   1.000
       1       0.0   1.000
FUNCTION: Accel Enrichment Multiplier Vs BP -[](O)
   Index        BP   Multiplier
       5    31.875   1.000
       4    30.000   1.000
       3    28.000   0.875
       2    20.000   0.625
       1     0.000   0.500
FUNCTION: VE Multiplier for ACT -[]
       5       254   1.188
       4       180   1.039
       3       150   1.000
       2      -256   1.000
       1      -256   1.000
FUNCTION: VE Multiplier for ECT
       5     254.0   1.000
       4    -256.0   1.000
       3    -256.0   1.000
       2    -256.0   1.000
       1    -256.0   1.000
FUNCTION: Desired Pressure Drop VS. Desired EGR Mass Flow
   Index      Flow   Pressure
      10   1.99997 127.000
       9   1.00000 127.000
       8   0.88000  60.000
       7   0.79999  50.000
       6   0.70001  40.000
       5   0.48001  20.000
       4   0.32001  10.000
       3   0.22000   5.000
       2   0.00000   2.000
       1   0.00000   0.000
FUNCTION: Closed Loop Ramp Rate Multiplier Vs. BIAS/PTPAMP
   Index      Bias   Ramp Rate
       5     0.498   0.996
       4     0.400   0.781
       3     0.301   0.633
       2     0.172   0.500
       1     0.000   0.500
FUNCTION: Exhaust Pressure Correction Vs. Baro
   Index        BP   Correction
       5    31.875  31.875
       4    24.500  26.625
       3    20.250  23.125
       2     0.000   8.000
       1     0.000   8.000
FUNCTION: Load Vs. Fuel Multiplier
   Index      Load   Multiplier
      11     1.992   0.469
      10     0.953   0.469
       9     0.898   0.672
       8     0.852   0.844
       7     0.797   0.961
       6     0.750   1.000
       5     0.000   1.000
       4     0.000   1.000
       3     0.000   1.000
       2     0.000   1.000
       1     0.000   1.000
FUNCTION: ECT/ACT Transfer
   Index  A/D Counts   °F
      10  1023.984   -40.0
       9   926.000   -40.0
       8   895.000    -9.0
       7   835.000    19.0
       6   737.000    46.0
       5   290.000   133.0
       4   148.000   179.0
       3    79.000   222.0
       2    50.000   254.0
       1     0.000   254.0
FUNCTION: Understanding Functions and Normalizers
   Index    X Axis   Y Axis
       5       255     255
       4       255     255
       3       255     255
       2       255     255
       1         0       0
SCALAR: Checksum                                                          6689 CKSUM
SCALAR: Checksum Start Address                                            8192 START
SCALAR: Checksum End Address                                             40958 END
SCALAR: Checksum Base                                                    40960 CK_BASE
SCALAR: ROM Size                                                         57343 Kb
SCALAR: Number of Calibrations                                               1 Calibrations
SCALAR: Owner | Processor Speed                                           12.0 M/hz Calibration
SCALAR: RLO Use Data                                                     57344 KEY
SCALAR: Trans Shift Light Minimum Timer RPM - Rev Limiter               6000.0 RPM
SCALAR: Shift Light Maximum RPM - Rev Limiter                           5000.0 RPM
SCALAR: Vehicle Speed Sensor Hardware Type                                   2
SCALAR: Number of HEGO Switches to Test                                      8
SCALAR: Accel Pump Multiplier                                            1.000 xMUL
SCALAR: Managed Fuel Air Logic Enabled                                       1 1=on, 0=off
SCALAR: Fuel Open Loop Startup Neutral Multiplier                        1.000
SCALAR: Fuel Open Loop Fuel Multiplier Time Delay                         40.0 Seconds
SCALAR: Injector Delay Global Adder                                     0.0000
SCALAR: Fuel Accel Minimum TP Movement                                  1023.0 TP
SCALAR: Intake Filling Model                                            0.9961
SCALAR: Fuel Transient Comp Multiplier                                   1.000 xMul
SCALAR: Fuel Equilibrium Intake Surface Multiplier                       1.000
SCALAR: Fuel Transient Compensation Switch                                   1 1=on, 0=off
SCALAR: Fuel Transient Minimum RPM Idle                                    200
SCALAR: Fuel Accel Multiplier                                           0.6016
SCALAR: Fuel Decel Multiplier                                           0.5000
SCALAR: Fuel Injector Low Slope -[](O)^                                 26.100 LBS/Hr
SCALAR: Fuel Injector Hi Slope -[](O)^                                  19.642 LBS/Hr
SCALAR: ISC Airflow Thru Throttle Body                                  0.5500 KG/Hr
SCALAR: ISC Minimum Airflow                                             0.0500 KG/Hr
SCALAR: ISC CL Above Idle RPM                                             90.0 RPM
SCALAR: ISC RPM Deadband                                                 30.00
SCALAR: ISC Max Load for Closed Loop                                   0.14844
SCALAR: ISC Min Load for Closed Loop                                   0.02734
SCALAR: ISC Neutral Idle Closed Loop Fuel Max Time -[](O)                255.0 Time
SCALAR: Idle Speed Neutral -[]                                             672 RPM
SCALAR: Idle Speed in Gear -[]                                             600 RPM
SCALAR: ISC Startup RPM Adder                                                0
SCALAR: ISC Startup Kickdown Time -[]                                       25 Seconds
SCALAR: ISC Startup RPM Time Adder                                           3 Seconds
SCALAR: Thermactor Air Logic Switch -[](O)                                   1 1=on, 0=off
SCALAR: Canister Purge Open Loop Enable                                      0 Switch
SCALAR: A/C Minimum Time Before Fan is On                                  3.0 Seconds
SCALAR: A/C Engage Maximum Temp                                          246.0 ° F
SCALAR: A/C Engage Maximum Temp Hysterisis                                12.0
SCALAR: Fan High Speed Enable Temp                                       242.0 ° F
SCALAR: Fan Low Speed Enable Temp                                        220.0 ° F
SCALAR: Fan High Speed Hysterisis                                          4.0 Hys Temp
SCALAR: Fan Low Speed Hysterisis                                           4.0 Hys Temp
SCALAR: Fan Low Speed VSS                                                 40.0 MPH
SCALAR: Fan Low Speed Hysterisis                                           5.0 MPH
SCALAR: Fan Low Speed Minimum Time Before High Speed                      10.0 Seconds
SCALAR: Fan A/C Minimum Time at Temp Active                               60.0 SECONDS
SCALAR: Low Speed Fan Enabled                                                0 Switch
SCALAR: High Speed Fan Enabled                                               0 Switch
SCALAR: High Speed Fan High Load RPM                                      1808 RPM
SCALAR: High Speed Fan Low Load Minimum                                 80.449 Load
SCALAR: Spark Adder for Closed Throttle                                   0.00 BTDC
SCALAR: Spark Adder for Part Throttle                                     2.00 BTDC
SCALAR: High Combustion Spark Discharge                                 1050.0 REPEAT
SCALAR: Spark Adder for Neutral                                           0.00 BTDC
SCALAR: Spark Adder for WOT                                               0.00 BTDC
SCALAR: Spark Limit Minimum Clip                                          0.00 BTDC
SCALAR: Spark Limit Maximum Clip -[]                                     42.00 BTDC
SCALAR: Part Throttle Spark Multiplier -[]                               0.953 Multiplier
SCALAR: Spark and Fuel Lugging Time Limit                                 3.00 Seconds
SCALAR: Spark Lugging Timer Switch                                           1 Switch
SCALAR: Spark Maximum PIP RPM                                            784.0 RPM
SCALAR: Spark Minimum PIP RPM                                            784.0 RPM
SCALAR: Part Throttle Breakpoint                                           8.0 TP
SCALAR: TP for WOT -[]                                                   555.0 TP
SCALAR: TP Voltage for WOT                                                2.71 Volts
SCALAR: NRUN                                                          16322.00 NRUN
SCALAR: NCNT                                                             176.0 Counts
SCALAR: EGR Part Throttle Adder                                           0.00
SCALAR: EGR Multiplier                                                   1.000 Multiplier
SCALAR: EGR Type Switch -[](O)                                               0 Switch
SCALAR: Minimum Load for Closed Loop Fuel Control                     0.0004883 Load
SCALAR: Minimum Load for Closed Loop Fuel Control Hysterisis          0.0002441 Load
SCALAR: Exhaust Pulse Delay -[](O)                                      8.6875 Delay
SCALAR: Time at High Load to Force Open Loop -[]                           2.0 Seconds
SCALAR: Closed Loop Maximum Lambda                                       1.300 LAMBSE
SCALAR: Closed Loop Minimum Lambda                                       0.750 LAMBSE
SCALAR: Number of Cylinders                                                  8 Cylinders
SCALAR: Fuel Injectors Per Output                                            1 NUM INJ
SCALAR: Number of Injectors                                                  8 Number of Injectors
SCALAR: Sequential Fire Switch                                               1 Switch
SCALAR: Open Loop Multiplier Global                                      0.996 Global Multiplier
SCALAR: Maximum Idle RPM at Closed Throttle                                800 RPM
SCALAR: DFSO Minimum RPM                                                   250 RPM
SCALAR: DFSO Neutral Maximum Time                                          3.0 Time
SCALAR: DFSO Minimum Time Part Throttle                                    3.0 Time
SCALAR: DFSO Minimum Shifting RPM                                          625 RPM
SCALAR: DFSO Minimum MPH                                                  25.0 MPH
SCALAR: DFSO Time Dealy                                                  255.0
SCALAR: Adaptive Control Minimum Lambda (Rich Point)                  0.421875 Lambda
SCALAR: Adaptive Control Maximum Lambda (Lean Point)                  0.621094 Lambda
SCALAR: Adaptive Minimum ECT -[]                                         176.0 ° F
SCALAR: Adaptive Maximum ECT                                             226.0 ° F
SCALAR: Adaptive Minimum ACT -[]                                         100.0 ° F
SCALAR: Adaptive Maximum ACT -[](O)                                      200.0 ° F
SCALAR: Adaptive Minimum Time at Set ECT -[](O)                          60.00 Seconds
SCALAR: Adaptive Idle Low RPM Only                                           0 1=on, 0=off
SCALAR: Minimum ECT for Hot Start -[]                                    170.0 ° F
SCALAR: Maximum ECT for Cold Start                                        56.0 ° F
SCALAR: Number of Revs Per PIP                                               4 1/2 Cyl
SCALAR: HEGO Reset Switch                                                    1 Switch
SCALAR: PIP Signature DC                                                 0.200 Decimal
SCALAR: REV Limit Maximum Fuel Cut                                      8000.0 RPM
SCALAR: REV Limit Maxiumum Hysterisis No Fuel                            100.0
SCALAR: Number of HEGO                                                       2 Switch
SCALAR: Mass Air Multiplier                                              1.000 Multiplier
SCALAR: Cubic Inch Displacement ^                                      301.082 CID
SCALAR: Scaling Multiplier                                                1.00 Multiplier
SCALAR: Transmission Strategy                                                1 Type Switch
SCALAR: Open Loop Lugging Minimum ECT                                    120.0 ° F
SCALAR: Open Loop Lugging Maximum ECT                                    220.0 ° F
SCALAR: Lugging Minimum Time for Open Loop                                31.0 Seconds
SCALAR: Estimated Tire Revs Per Mile                                     768.0 Est. Tire Revs
SCALAR: VSS Pulse Per Mile                                             8000.00 Est. PPM
SCALAR: MIL LOGIC                                                            1 Switch
SCALAR: MIL SEND                                                             1 Switch
SCALAR: MIL RECEIVE                                                          1 Switch
SCALAR: MIL EVAP                                                             1 Switch
SCALAR: MIL ECT                                                              1 Switch
SCALAR: MIL ACT                                                              1 Switch
SCALAR: MIL SLI                                                              1 Switch
SCALAR: MIL RSD                                                              1 Switch
SCALAR: Tip In Spark Retard                                             -20.00 BTDC
SCALAR: Speed Limiter A -[]                                              116.0 MPH
SCALAR: Speed Limiter A On/Off -[]                                       113.0 MPH
SCALAR: Speed Limiter B -[]                                              112.0 MPH
SCALAR: Speed Limiter B On/Off -[]                                       110.0 MPH
SCALAR: Rev Limit Half Fuel Off -[]                                     5900.0 RPM
SCALAR: Rev Limit Half Fuel On                                          6200.0 RPM
SCALAR: TP Max Voltage                                                 4.83871 Voltage
SCALAR: TP Min Voltage                                                 0.19550 Voltage
SCALAR: Understanding Scalars                                                0 EXAMPLE
SCALAR: Search Keys                                                          0 DO NOT ENTER
FLAG: Understanding Switch Flags                                     Not Set
Dashing ZX2
Well, I finally got a crack at trying out those definitions and bins. Took awhile to to get the motor swapped but its running now.
Using A1C it will sputter and try to fire, but it doesn't sound like its trying to fire on all 8, never got it to fire up. I didn't go looking around in it yet if there's some configuration for number of cylinders.
C9C1, fires up, but barely and it won't hold an idle. It generally ran like crap but it did run, sounded like all 8 on this one too.
For some reason the tunerpro dash wasn't giving data, so I couldn't do any live troubleshooting. So, does it seem like these could work with some configuring?
Dashing ZX2
I'm getting around to messing with the C9C1 bin to try to get it to work. I noticed that C9C1 is batch fire since NUMOUT is 2 and INJOUT is 4, but I this engine should be sequential. Would changing these values to reflect a sequential setup work?
Another thing, since C9C1 is for a truck engine, it would be for the flat tappet cam engine and this Lincoln engine is roller like the mustang, so different cam specs. Could it be that it's just running poorly due to different amounts of air getting in the engine so the fuel requirements are different? If so, it should be possible to play with the VE table to get it to run well whether it is batch or sequential. My assumption is that, at least for idle, the VE should be less considering this cam is more aggressive than a flat tappet truck cam.
Last thing for this post, is there a readme file or something for the xdf? When hovering over the different parameters the popup goes away too quickly for me to read much. I'd like to be able to read all those notes easier.
Post by decipha »
press f10 in tunerpro for the comments
No, all that you said doesn't make any sense.
you can sequential a batch ecu, not enough outputs, doesn't make any difference though
that lincoln ecu is probably going to be a different hardware class altogether. Here's a v8 5.0 c9c1 tune. Change the injector size to 19 from 24 (which it actually has 30s) and give it a go to see if it actually runs correctly and fires all the cylinders, if so just put your actual injector data in and dial in the ve table. You will need to kick up the crank pw by multiplying by 1.57 (30/19).
make sure you have the correct adx loaded in. Did you enable datalogging in your tune file before writing? This file has the datalogging patch already enabled.
enjoy and post back your results
AJON_121220d4.bin
(56 KiB) Downloaded 920 times
