Scalar Function
DOHCTOR_32V
Scalar Function
Hello, could someone please give me a brief explanation of what the pictured scalars do in relation to the injector timing table? Thanks
Re: Scalar Function
It bypasses the injector timing table and sets injector timing to 500 at idle and in neutral
DOHCTOR_32V
Re: Scalar Function
Cool. Thank You
DOHCTOR_32V
Re: Scalar Function
What happens with the table and injector timing when out of idle, and in drive? Does "Frequency Input Falling Edge" log this?
Re: Scalar Function
Those scalars don't get used and the table does instead.
No thats for the moates superlogger device
DOHCTOR_32V
Re: Scalar Function
Super! Thank You for the insight.
DOHCTOR_32V
Re: Scalar Function
decipha, just to be sure these parameters are dependent on one another, I'd like to ask ... from the attached picture, does changing these two switches to "un-set" cause the other two, 500 degree injector timing values to have no effect? I only want the Injector Timing table and Injection Timing ECT modifier to be used. I'm not currently using 500 degrees in my table.
Re: Scalar Function
correct
DOHCTOR_32V
Re: Scalar Function
I appreciate your shared knowledge. Thanks
