[Wanted] 351W E4OD stock tune
yaboyhalle
Vehicle Information: 1995 F150 SCLB 351W E4OD SD47B
1993 Mustang SVO swap EFR7163 PiMPxs
Post by yaboyhalle »
Currently trying to return a new to me truck to stockability again. It was running on an SD2x EEC, with what i assume is a 5.0 manual tune, spout out, timing locked to ~30. Not the best home mechanic.
Best replacement i could find was a SD47B EEC with a 5.0 E4OD stock tune. I'd rather start with the right calibration on this correct hardware.
rusty_lawrence
WAY1 / SMD-221 / AHAC2
Novi 2000 intercooled S/C
Re: [Wanted] 351W E4OD stock tune
Post by rusty_lawrence »
this is one from my lightning
C3P2.bin
(34.24 KiB) Downloaded 919 times
Post by wwhite »
Here is a 1994 351w E4OD non-lightning SD48B.
I had ran the stock C3P2 on a stock non-lightning 351w and would pop/backfire through intake in certain conditions.
KID2.bin
(56 KiB) Downloaded 1212 times
I believe LAD1 is the newest code (1996) for 351w E4OD.
LAD1.bin
(56 KiB) Downloaded 1235 times
yaboyhalle
Thanks for the help. I was able to modify a Z2D tune with data from the LAD1 and it worked perfectly. Truck is up and moving!
yaboyhalle
Came into another sd48B, with stock bin LE01. Is it just me, or are the 351w tunes (LAD1, KID2, and this LE01) not reading on the A1C.xdf?
LE01_94351e4od.bin
(56 KiB) Downloaded 583 times
Post by decipha »
they arent going to its a different strategy
you have to use the a1c files provided in that thread
Post by wwhite »
yaboyhalle wrote: 2025 Aug 12, 22:38 Came into another sd48B, with stock bin LE01. Is it just me, or are the 351w tunes (LAD1, KID2, and this LE01) not reading on the A1C.xdf?
Thats L - lima E - echo O - oscar - 1 (LEO1), not LE zero one(LE01).
That is 100% identical to KID2, exactly.
Very different than A1C.
yaboyhalle
It seems a bit too thin to be an Oh, but I wouldn't know what font they're using. Either way, I was just looking to find an A1C bin for a 351, as adapting a 302 tune isn't as easy.
Post by wwhite »
The O do not have a line through them like the zeros.
Googling these codes, makes a difference.
I tend to be a bit pedantic with this stuff.
Post by wwhite »
yaboyhalle wrote: 2025 Aug 29, 20:19 It seems a bit too thin to be an Oh, but I wouldn't know what font they're using. Either way, I was just looking to find an A1C bin for a 351, as adapting a 302 tune isn't as easy.
The A1C.bin is located in the first post of this group.
You must use the matching XDF.
