03 Lightning strategy PCM catch code is NLP2
Can be used on all 2002-2003 harley trucks and lightnings.
mbsvt1
Vehicle Information: 1992 Ford Mustang 5.0 LX vert 5 speed summer edition
347 cid
Long tubs 2.5 full Exhaust
Comp Cams extreme energy 282
Unread post by mbsvt1 »
I have an 03 Lightning catch code NLP2 on my PCM
Question which strategy do I use? Can not find it in the EEC Master Hardware List. Should I use the OMAE2?
Thank you MB
Re: 03 Lightning strategy PCM catch code is NLP2
correct
you have to use the ek02 cal as well, copy over your vin and pats and plug in your actual tire size and rear gear ratio
then enjoy
