I have an 03 Lightning catch code NLP2 on my PCM
Question which strategy do I use? Can not find it in the EEC Master Hardware List. Should I use the OMAE2?
Thank you MB
03 Lightning strategy PCM catch code is NLP2
mbsvt1
- Vehicle Information: 1992 Ford Mustang 5.0 LX vert 5 speed summer edition
347 cid
Long tubs 2.5 full Exhaust
Comp Cams extreme energy 282
Re: 03 Lightning strategy PCM catch code is NLP2
correct
you have to use the ek02 cal as well, copy over your vin and pats and plug in your actual tire size and rear gear ratio
then enjoy
then enjoy
