[A1C] Strategy Files
Locked
EFI-SD4x - 80s/90s V8 and 6 cyl speed density with manual or E4OD auto trans.
Bronco, F-150, Lightning, etc.. REPLACES catch code JOY0, etc...
A1C, Z2D and Z2D1 cal's all use this strategy natively.
94STK__d7_final.bin
6 cylinder I-300 4.9L stock engine MANUAL
Stock 94 F-150 MANUAL TRANS w/ baby cam
ANT0 ecu. 216rwhp, 381rwtq
(56 KiB) Downloaded 633 times
DMAC_240311aa5_C2b.bin
5.8L 351W GT40 stock engine AUTO
93 Lightning 42lb injectors @40psi, supercharged 8 lbs boost, punisher vb, otherwise 100% stock w/ e4od trans 4.10 gears
(56 KiB) Downloaded 1285 times
DSCH_230227e7.bin
5.7L 347ci 5.0L (302) stroker MANUAL
60lb inj, 87 oct, cam, e7 heads, manual trans
(56 KiB) Downloaded 1303 times
A1C_240409.xdf
PREV posted 24-03-14
(386.29 KiB) Downloaded 2147 times
DECIPHA_240219.adx
datalogging file a1c already selected
updated feb 2024 for wideband
(443.86 KiB) Downloaded 2159 times
Z2D1.bin
update to A1C, predecessor to Z2D
v8 5.0
(56 KiB) Downloaded 2187 times
Z2D.bin
update to Z2D1. Z2D is the latest ford stock update.
v8 5.0
(56 KiB) Downloaded 2089 times
A1C.bin
stock v8 tune file predecessor to Z2D1
(56 KiB) Downloaded 2249 times
Re: [A1C] Strategy Files
adx attached
figured out yesterday the opclt scalars are actually the ectstabl scalars
will be posting new xdf sometime next month
Not sure how but the previous xdf was from feb 11 of 2021. Major updates since then new file just posted.
updated xdf filed psphp pfehp mismatch and a few other updates / corrections / parameter additions
updated xdf and adx to log wideband correctly
added trans shifting stuff
fixed a bunch of incorrect stuff
did other stuff im sure
2-1 and 3-2 shift schedules were backwards. Fixed.
added a bunch of trans related stuff, tq stuff, mbt spark and a tcs hold 1st gear patch
Added 93 lightning tune w/ punisher valve body ford 42lb injectors @ 40psi stock pressure and powerdyne at 8lbs of boost. Otherwise all original and stock 93 lightning truck.
New 6 cylinder straight 300 manual trans tune will be posted soon.
<--- posted above --->
Locked
