[A1C] Strategy Files
EFI-SD4x - 80s/90s V8 and 6 cyl speed density with manual or E4OD auto trans.
Bronco, F-150, Lightning, etc.. REPLACES catch code JOY0, etc...
A1C, Z2D and Z2D1 cal's all use this strategy natively.
- 94STK__d7_final.bin
- 6 cylinder I-300 4.9L stock engine MANUAL
Stock 94 F-150 MANUAL TRANS w/ baby cam
ANT0 ecu. 216rwhp, 381rwtq - (56 KiB) Downloaded 24 times
- DMAC_240311aa5_C2b.bin
- 5.8L 351W GT40 stock engine AUTO
93 Lightning 42lb injectors @40psi, supercharged 8 lbs boost, punisher vb, otherwise 100% stock w/ e4od trans 4.10 gears - (56 KiB) Downloaded 662 times
- DSCH_230227e7.bin
- 5.7L 347ci 5.0L (302) stroker MANUAL
60lb inj, 87 oct, cam, e7 heads, manual trans - (56 KiB) Downloaded 724 times
- A1C_240409.xdf
- PREV posted 24-03-14
- (386.29 KiB) Downloaded 1461 times
- DECIPHA_240219.adx
- datalogging file a1c already selected
updated feb 2024 for wideband - (443.86 KiB) Downloaded 1472 times
- Z2D1.bin
- update to A1C, predecessor to Z2D
v8 5.0 - (56 KiB) Downloaded 1575 times
- Z2D.bin
- update to Z2D1. Z2D is the latest ford stock update.
v8 5.0 - (56 KiB) Downloaded 1466 times
- A1C.bin
- stock v8 tune file predecessor to Z2D1
- (56 KiB) Downloaded 1632 times
Re: [A1C] Strategy Files
adx attached
figured out yesterday the opclt scalars are actually the ectstabl scalars
will be posting new xdf sometime next month
Not sure how but the previous xdf was from feb 11 of 2021. Major updates since then new file just posted.
updated xdf filed psphp pfehp mismatch and a few other updates / corrections / parameter additions
updated xdf and adx to log wideband correctly
added trans shifting stuff
fixed a bunch of incorrect stuff
did other stuff im sure
2-1 and 3-2 shift schedules were backwards. Fixed.
added a bunch of trans related stuff, tq stuff, mbt spark and a tcs hold 1st gear patch
Added 93 lightning tune w/ punisher valve body ford 42lb injectors @ 40psi stock pressure and powerdyne at 8lbs of boost. Otherwise all original and stock 93 lightning truck.
New 6 cylinder straight 300 manual trans tune will be posted soon.
Here's a sneak peek.
- NW_94STK__D1.bin
- 94' Stock F-150 I-300 Manual Trans w/ baby cam
ANT0 catch code - otherwise all stock - (56 KiB) Downloaded 292 times
