Happy Halloween '21
Happy Halloween '21
Hope all has a good all hallows eve.
Halloween is a major holiday in my family we go all out. Looks like its shaping up well.
Turbo Tbird
Vehicle Information: 1993 Ford Thunderbird SC
3.8L V6
Precision 6062 Gen2, 0.82 AR turbine housing
8.8:1 compression
polished SC crank
Ross custom pistons
Eagle rods
custom grind cam, 216/216, 0.588" w/ 1.73 ratio, 112 LSA
SCUI "stage 1" split port heads
ported 99-00 Mustang upper and lower intakes
stock 99-00 Mustang throttle body
Comp Pro Magnum 1.7 rocker arms w/ Morana guideplates
Hy-lift Johnson 2368S short travel lifters
dual valve springs
NGK BR7EF plugs gapped @ 0.020
Precision 46mm waste gate
3" exhaust w/ cutout
FMIC
SCT BA5000 MAF
Tial Q 50mm BOV
80lb Siemens Deka injectors
modified F-150 4.2 fuel rail
VW/Audi adjustable FPR @ 60 psi base fuel pressure
Walbro 450 HP pump
8AN feed, 6AN return
Innovate SCG-1 boost controller & wideband
wbo2_lc1mtxl
Re: Happy Halloween '21
Unread post by Turbo Tbird »
Happy Halloween Decipha!! :D
