Hope all has a good all hallows eve.
Halloween is a major holiday in my family we go all out. Looks like its shaping up well.
Happy Halloween '21
Turbo Tbird
- Vehicle Information: 1993 Ford Thunderbird SC
3.8L V6
8.8:1 compression
polished SC crank
Ross custom pistons
Eagle rods
dual valve springs
NGK BR7EF plugs gapped @ 0.020
Precision 46mm waste gate
3" exhaust w/ cutout
FMIC
SCT BA5000 MAF
Tial Q 50mm BOV
80lb Siemens Deka injectors
modified F-150 4.2 fuel rail
Walbro 450 HP pump
8AN feed, 6AN return
wbo2_lc1mtxl
Re: Happy Halloween '21
Happy Halloween Decipha!! :D
