Ignition Table Suggestions
beyondeod
Vehicle Information: 1995 Mustang GT, 306ci 9.5:1, GT40p Heads, 214/218 108LSA FTI Cam, Explorer Intake, 65mm BBK TB, PIMPXShift MS3 ECU
Unread post by beyondeod »
Hello Michael,
I have come back to the place I consider my source for most things tuning on the Fords. Thanks for keeping all this information up to date and online.
I am working on building out my base Ignition table for my MS3 powered Mustang. Based on your writeup (28 MBT, 36 Cruise) I might be too aggressive on my table. I'd appreciate your opinion.
Shooting for an 800 rpm Idle.
Current Ign Table
Current Ign Table
Re: Ignition Table Suggestions
i would add 8 degrees from 45 on down
95 subtract 4, copy that to 105 and then blend everything between
beyondeod
Thank you sir, Ill see how that works out
