CXN1-01 Lightning need Strategy
00/01 SVT Lightning
SVTF150
Supporting Member 1
Vehicle Information: 2001 Ford F150 Lightning #6 Lower Metco QC pulley ,20" Rep Whl. PCM CC (CXN1)
Unread post by SVTF150 »
Im looking for some help with setting up TunerPro RT need the associated files to be able to tune my truck i talked to Mr Moates and gave him a breakdown of the files i had and he said it was all wrong :| and that they didnt have much support out there for that strategy so he sent me over here im hoping incan get this going because i already purchased the hardware\Quarterhorse thats my fault for not doing the research first :oops:
Re: CXN1-01 Lightning need Strategy
MNAE0 is a premium member strategy
http://www.efidynotuning.com/remote.htm
If your lightning is modified youll need to become a premium member otherwise if its all stock or basically stock I can post an xdf for you but hadnt finished the logging since no premium member has used it yet.
SVTF150
Supporting Member 1
it is all stock just has a 6lb lower pulley been running on the stock tune for a long time i just want to be able to add a little fuel up top and just be able to communicate with it and would datalogging be something we could get working but im assuming i would have to become a premium member for that?
Nah its not neccessary. Give me a couple days to crunch it out and I'll post it along with a base tune.
SVTF150
Supporting Member 1
Wow man that's awesome Thank you for your time
yeah no problem
go ahead and read out your stock tune and post it here so i can copy over your pats code and vin
SVTF150
Supporting Member 1
okay
m-barans
Unread post by m-barans »
I’m also interested in being able to work with this strategy.
yea I thought of you when this popped up. Theres been a couple others expressing interest as well so figured id toss it on my to do list. I already have most of this strat disassembled with my own short hand xdf for the trucks I tune I just need to make a user friendly xdf for yall and restructure the logging for the latest adx.
SVTF150
Supporting Member 1
thats great its just weird that you cant find anything on that strategy you are the only one that comes close to having a handle on it am i the only one with one of these things lol well heres my tune i think i got it right let me know if it is
stocktuneSVTF150.bin
for Mr Decipha
(256 KiB) Downloaded 2485 times
