CXN1-01 Lightning need Strategy
SVTF150
- Supporting Member 1
- Vehicle Information: 2001 Ford F150 Lightning #6 Lower Metco QC pulley ,20" Rep Whl. PCM CC (CXN1)
Im looking for some help with setting up TunerPro RT need the associated files to be able to tune my truck i talked to Mr Moates and gave him a breakdown of the files i had and he said it was all wrong
and that they didnt have much support out there for that strategy so he sent me over here im hoping incan get this going because i already purchased the hardware\Quarterhorse thats my fault for not doing the research first
Re: CXN1-01 Lightning need Strategy
MNAE0 is a premium member strategy
If your lightning is modified youll need to become a premium member otherwise if its all stock or basically stock I can post an xdf for you but hadnt finished the logging since no premium member has used it yet.
SVTF150
it is all stock just has a 6lb lower pulley been running on the stock tune for a long time i just want to be able to add a little fuel up top and just be able to communicate with it and would datalogging be something we could get working but im assuming i would have to become a premium member for that?
Nah its not neccessary. Give me a couple days to crunch it out and I'll post it along with a base tune.
SVTF150
Wow man that's awesome Thank you for your time
yeah no problem
go ahead and read out your stock tune and post it here so i can copy over your pats code and vin
SVTF150
m-barans
I’m also interested in being able to work with this strategy.
yea I thought of you when this popped up. Theres been a couple others expressing interest as well so figured id toss it on my to do list. I already have most of this strat disassembled with my own short hand xdf for the trucks I tune I just need to make a user friendly xdf for yall and restructure the logging for the latest adx.
SVTF150
thats great its just weird that you cant find anything on that strategy you are the only one that comes close to having a handle on it am i the only one with one of these things lol well heres my tune i think i got it right let me know if it is
- stocktuneSVTF150.bin
- for Mr Decipha
- (256 KiB) Downloaded 2486 times
