I'm lookin to start tuning my 95 F150 but I can't find the strategy file for CBAZ0 and the only HUG2 bin file I can find seems to be incomplete. The CBAZ0 file on the EFIDynoTuning website just brings me here. I've heard someone named sailorbob has a HUG2 file available to buy.
1995 F150 MAF 302 4r70w 2wd
Does anyone have the files for this strategy and bin?
Is CBAZA close enough to run a HUG2 file if I find one or is there a Mustang bin file that can be modified to run my truck?
95 F150 xls and bin
DataWizard
- Vehicle Information: 1995 Ford F150 XLT Flareside CBAZ0 HUG2
Re: 95 F150 xls and bin
all of the above
cbaz0 is the exact same class ecu and cal as-is/and replaceable by cbaza. simply edit a cbaza tune for your 4r70w trans *if applicable*,1 ego, disable the fans and your good to go.
fyi, (as a side note for a ford history lesson), HUG2 was the 'corrected' cal to the JAB1 which henry mistakenly released by accident as it had some errors in it.
I attached a 'stock' 95 f150 cbaza file 'HUG3' to the cbaza strategy thread for your enjoyment. Simply modify that for your mods same as you would the stock read out and simply tune from there.
btw, I see your local. I drive through st.rose everyday and will actually be out at IMTT next week.
