How to adjust base idle effectively?
m-barans
Unread post by m-barans »
I am wondering how to bump idle effectively… I can change Neutral Base and Drive Base values but it seems like idle spark or something else needs a tweak. Can Someone please tell me how to do this properly? Thanks
Re: How to adjust base idle effectively?
bump up idlrpm as well
