INJECTOR DATA SHEET AT 60PSI OR 65PSI
Can be used on all 2002-2003 harley trucks and lightnings.
jgomez
Vehicle Information: 2003 ford lightning NLP2
Unread post by jgomez »
good night
Does anyone have data sheet on Siemens 80lb/hr injectors @ 60psi or 65psi?
rusty_lawrence
Vehicle Information: 1994 F150 Lightning
WAY1 / SMD-221 / AHAC2
Novi 2000 intercooled S/C
Re: INJECTOR DATA SHEET AT 60PSI OR 65PSI
Unread post by rusty_lawrence »
I had this on file
m-9593-lu80.pdf
(13.5 KiB) Downloaded 765 times
jgomez
Thank you very much but I need the information for 60 psi or 65 psi
rusty_lawrence
Uh. 60 is there…isn’t it? Doesn’t go to 65.
jgomez
ok i get it, your right
thanks so much
