good night
Does anyone have data sheet on Siemens 80lb/hr injectors @ 60psi or 65psi?
INJECTOR DATA SHEET AT 60PSI OR 65PSI
jgomez
- Vehicle Information: 2003 ford lightning NLP2
rusty_lawrence
WAY1 / SMD-221 / AHAC2
Novi 2000 intercooled S/C
Re: INJECTOR DATA SHEET AT 60PSI OR 65PSI
I had this on file
- m-9593-lu80.pdf
- (13.5 KiB) Downloaded 763 times
jgomez
Thank you very much but I need the information for 60 psi or 65 psi
rusty_lawrence
Uh. 60 is there…isn’t it? Doesn’t go to 65.
jgomez
ok i get it, your right
thanks so much
thanks so much
