Non-Intetcooled Turbo Setup
Novi347
Vehicle Information: 1990 Foxbody (Original Owner)
363 Turbo Build in Progress.
*Last Setup: 349 Novi2000
Unread post by Novi347 »
After over 24yrs of supercharging, I'm making a switch to a Turbo combination. Just ordered an FIS GTRS47696 for my 363 build. Question is for individuals who use meth injection solely instead of intercooling? I've had great success doing it on my Blown application in the AZ summer. At full boost of 20lbs my IATs were steadily in the 90 deg range. What type of IATs do turbos reach when street driving? Thanks in advance!
Re: Non-Intetcooled Turbo Setup
I've never ran a turbo setup without an intercooler but should be pretty similar if not just a touch more.
You'll be good.
Novi347
Ok, Thank you. Tried asking guys at FIS, he said exhaust housing can reach up to 2000 deg. I Assumed that was at full load.
The turbine housing gets pretty hot but not so much for the compressor housing.
