GMAIL and Hotmail - use alternate email address
The following email servers are not able to receive bookmark and other notifications from the forum.
@gmail.com
@hotmail.com
Would be best to use your cell phone number to get text messages instead.
Here's a link to cell phone number to email address for your carrier.
https://avtech.com/articles/138/list-of ... addresses/
dnschneid
Vehicle Information: 1995 Ford F150 XLT 4x4 5L manual M5OD-R2 (might upgrade to ZF5 later), 3.55 diffs, 30" tires (31.7" planned), e-fan (separate temp sensor, Flexalite 295)
EFI-SD42F / JOY0
Tuning a 347 w/ RV cam, 1.7 rollers, 60lb deka injectors, but otherwise stock (in particular the stock 30-45lb FPR). Emissions vehicle.
WB_AEM-X
Re: GMAIL and Hotmail - use alternate email address
Unread post by dnschneid »
Yeah, it looks like your domain is set up with protonmail's SPF, but the last time I received an email from the forum (before Google changed the policy to hard-fail), it was from a different IP:
ARC-Authentication-Results: i=1; mx.google.com;
       spf=softfail (google.com: domain of transitioning forum@efidynotuning.com does not designate 198.71.225.98 as permitted sender)
which appears to be secureserver.net. I'm guessing that's your phpbb SMTP server.
My best guess is you need to update your domain's TXT entry to something like:
v=spf1 include:_spf.protonmail.ch include:spf-0.secureserver.net mx ~all
GoDaddy just had a major outage, not known by many.
Had zero email from last Thursday to Sunday, was a Godaddy email routing issue, first time I had to call support, took 3 hours on the phone.
Yeah i made a post as they had a transfer issue on a server and the site went down for 45 min, i just so happened to be posting when it happened. I too had to call them.
dschneid... correct xX, should be all good here shortly, hopefully.
dnschneid
EFI-SD42F / JOY0
WB_AEM-X
Yep, just got an email notification for this thread to my gmail!
rusty_lawrence
Vehicle Information: 1994 F150 Lightning
WAY1 / SMD-221 / AHAC2
Novi 2000 intercooled S/C
Unread post by rusty_lawrence »
I have never been able to receive notifications in gmail. Is this something that was recently corrected? Can I re-add my gmail address to my profile?
Should be, others are receiving them now as well.
