The following email servers are not able to receive bookmark and other notifications from the forum.
@gmail.com
@hotmail.com
Would be best to use your cell phone number to get text messages instead.
Here's a link to cell phone number to email address for your carrier.
https://avtech.com/articles/138/list-of ... addresses/
GMAIL and Hotmail - use alternate email address
dnschneid
- Vehicle Information: 1995 Ford F150 XLT 4x4 5L manual M5OD-R2 (might upgrade to ZF5 later), 3.55 diffs, 30" tires (31.7" planned), e-fan (separate temp sensor, Flexalite 295)
EFI-SD42F / JOY0
Tuning a 347 w/ RV cam, 1.7 rollers, 60lb deka injectors, but otherwise stock (in particular the stock 30-45lb FPR). Emissions vehicle.
WB_AEM-X
Re: GMAIL and Hotmail - use alternate email address
Yeah, it looks like your domain is set up with protonmail's SPF, but the last time I received an email from the forum (before Google changed the policy to hard-fail), it was from a different IP:
which appears to be secureserver.net. I'm guessing that's your phpbb SMTP server.
My best guess is you need to update your domain's TXT entry to something like:
ARC-Authentication-Results: i=1; mx.google.com;
spf=softfail (google.com: domain of transitioning forum@efidynotuning.com does not designate 198.71.225.98 as permitted sender)
v=spf1 include:_spf.protonmail.ch include:spf-0.secureserver.net mx ~all-
GoDaddy just had a major outage, not known by many.
Had zero email from last Thursday to Sunday, was a Godaddy email routing issue, first time I had to call support, took 3 hours on the phone.
Yeah i made a post as they had a transfer issue on a server and the site went down for 45 min, i just so happened to be posting when it happened. I too had to call them.
dschneid... correct xX, should be all good here shortly, hopefully.
dnschneid
EFI-SD42F / JOY0
WB_AEM-X
Yep, just got an email notification for this thread to my gmail!
rusty_lawrence
WAY1 / SMD-221 / AHAC2
Novi 2000 intercooled S/C
I have never been able to receive notifications in gmail. Is this something that was recently corrected? Can I re-add my gmail address to my profile?
Should be, others are receiving them now as well.
