ZYA2 not work?
mechanicalmatch
- Vehicle Information: 00 F150 4.6L Extended cab
CVAF1
4R70 3.08
Re: ZYA2 not work?
I took the bin decipha posted, put your vin and pats key in, and converted with custom ecm 's bank swap tool. I then compared it to the one you posted. Hex editor shows no differences. Makes me think that maybe there is an issue with the tool. Try converting manually the bin manually and do a bin compare and see if the code is there. Info on the bank swapping process is in the "eec disassembly" write up.
Red Mach1
- Vehicle Information: 2003 Mach1, stock engine with Comp cams 106100
Re: ZYA2 not work?
Ok. Thanks much. I tried convert amz2 for cobra and no error after write...only with zya2...I will convert manually but dont understand whats mean insert 65536 look attachment
Red Mach1
Re: ZYA2 not work?
mechanicalmatch
CVAF1
4R70 3.08
Re: ZYA2 not work?
65536 bytes or 0x1000 bytes
Re: ZYA2 not work?
I think the issue is the ZYA2 is corrupt. i tried loading it in my car Saturday and the fan and fuel pump ran continuously and i got the dashes in the odometer.
Red Mach1
Re: ZYA2 not work?
Yes not work... I tried amz cobra tune and car start with stock amz without modifications, zya2 and sym2 not work
