Speed Limiter Issue?
Used on mid 90s mass-air broncos and F-Series trucks. SMD-221 Hardware.
Cal Codes: HOG0, HOG1, TIP1, VEX1, WAY1
BOOSTED347
Vehicle Information: 1992 Ford Mustang Lx
347 Stroker Turbocharged
A9L tuned on TunerProRT
Re: Speed Limiter Issue?
Unread post by BOOSTED347 »
It’s a 95 F150 with the lightning drivetrain. Using AHAC2 to tune it. Is there other things I can try to fix this issue or is it really because of the Inj dc maxing out?
No if its hitting a limiter then the injector duty cycle is another issue altogether.
If that moved it then your either hitting that limiter still due to kam correction or you found another.
post the tune file
BOOSTED347
95 F150 351W.bin
(56 KiB) Downloaded 943 times
Was able to post the tune
give her a try
95 F150 351W_tst2.bin
(56 KiB) Downloaded 895 times
BOOSTED347
Currently out of town for work. Will give it a try once I get back.
any luck?
BOOSTED347
Was able to try it out and still doing it. I’m thinking it has to be the psom now because the needle started to bounce around. Only does it when in drive but not in manual 1st & 2nd
did you crank up the fuel pressure? Starving for fuel can seem like a limiter. Popping, missing breaking up or it just lays down. all could be from fuel. the 19# injectors are too small unless you crank up the pressure a D said.
