EL falcon 6 cyl eec running 5.0 v8
Specific to none US ford tuning as some of the algorithms are slightly different.
Re: EL falcon 6 cyl eec running 5.0 v8
thats cuz theres a newer patch in the tune than in the xdf
it should have logged perfectly all you had to do is click the button
Jamie from oz
ok i will load it again.
thank you
Jamie from oz
just confirming that the A!C is 8061 processor ??
the HWAD3 (auto) and HWMC2 (manual) are 8065 processors.
i am slowly sorting out the tune and will post it soon .
Jamie from oz
these are the TI Performance base files.
i dont think i changed them.
6dbd.bin goes with HWAD3
think i worked out how to attach as my computer skills are just above clicking a mouse hahaha.
6dbd.bin
(256 KiB) Downloaded 936 times
HWMC2_v13_256K.xdf
(119.04 KiB) Downloaded 965 times
HWAD3_v10_256K.xdf
(84.08 KiB) Downloaded 923 times
Jamie from oz wrote: ↑2022 Aug 14, 17:35 just confirming that the A!C is 8061 processor ??
# Disassembly listing of binary 'A1C'    8061  1 bank     SAD Version 4.0.7.16b (11 Apr 2022)
# See 'A1C_msg.txt' for warnings, results and other information
yes a1c is eec-iv 8061 ecu from 80s to 90s
Jamie from oz
decipha wrote: ↑2022 Aug 16, 09:00 yes a1c is eec-iv 8061 ecu from 80s to 90s
This will be why his A1c_aussie_test bins will not data log on our 60 pin eec-v 8065 .
wasnt sure if he had done some hack to be able to try it on our ecu.
yeah it shouldn't even execute
decipha wrote: ↑2022 Aug 17, 07:50 yeah it shouldn't even execute
The 8065 uP will run 8061 software no problem, backwards compatible correct?
I'm going to go a different route with this.
The 6dbd.bin, is speed density and runs on 8065 correct?
My 351w is speed density, so...I'll take my EEC-V 104 pin and run the 6dbd single bank software on it.
Be intersting if it works, then the repinning, etc. etc.
No, for starters the 8061 stack SFR address is different to 8065.
