1989 Mustang with a complete 4.6 swap from an '02 Mustang GT (wiring harness, CCRM, gauge cluster, etc.).
Drivetrain was stock last year, all functioned normal and drove great.
This year I added a Paxton blower and supporting mods, using TunerPro and a Quarterhorse with an FBGI0 definition. Tune is working pretty good, but still a work in process.
Here's the issue...As the title says, neither my low nor high speed fan will turn on with the A/C. It functions normally, otherwise and with the A/C on, it'll still cycle on and off with engine temp and the compressor still kicks on and off, the fan just ignores that the A/C is turned on. This started when I installed the quarterhorse.
I have attached the file I'm using if anybody would like to take a look at it for me.
Thanks!
Fan not turning on with A/C
ryanstout88
- Vehicle Information: 4.6 Swapped 89Coupe
- FBGI0_210226.xdf
- (1.74 MiB) Downloaded 435 times
- ModFox8.bin
- (256 KiB) Downloaded 506 times
Re: Fan not turning on with A/C
post your ecu tune file too
no need in posting the xdf
ryanstout88
I’m lost on what file you need, you may need to get out the crayons LOL.
The ecu is an MDE2.
The ecu is an MDE2.
read the tune off the ecu that has the fans operating correctly
ryanstout88
Ahhh, my bad. Honestly I never pulled the stock file out before I started the project. I just grabbed the FBGI0 and started going to town.
TunerPro is cool, but I'm still set in my HPTuners ways, haha. I'll see if I can compare em tomorrow morning and see what's up.
File uploaded.
EDIT: Wow, apparently I have a few things that I need to go through when I get a moment to sit down and compare these. I'll post if I get it fixed. I really appreciate the willingness to help, I still may need it.
Some of these tables in the stock bin look pretty messed up (borderline knock, MAF transfer, to name a couple), did something happen?
File uploaded.
- MDE2.bin
- (256 KiB) Downloaded 464 times
your looking at two different strategies so it not going to be show correctly
thats just a stock mde2 file
i dont see anything that would cause the fans not to work correctly
ryanstout88
Weird. I’ll do some digging with it later tonight and if nothing else, I figured I’d wire up something like this…
if it worked before it should work now
id gove it a good look over
ryanstout88
Update: I have narrowed it down to a CCRM issue.
I should've ran through everything first, but figured that the last thing I added was the Quarterhorse. Thanks for looking over it for me, Decipha, it's appreciated.
