[solved] convert 224K to 256K
- Vehicle Information: x3 1997/2000 PUMA 1.7 MUFF / TAPE / DUDE
1997 PUMA 1.4 PEST
2001 PUMA 1.6 CHCA
MONDEO MK3 ST220 6BDB
MONDEO MK3 DURATEC25 1RRC
Re: convert 224K to 256K
I don't delete 65536, i don't put it
look at this
look at this
1997 PUMA 1.4 PEST
2001 PUMA 1.6 CHCA
you can confirm me that start adress for the bank in 256k files
bank 0 start adress 0x02000
bank 1 start adress 0x12000
bank 8 start adress 0x22000
bank 9 start adresss 0x32000
and bank order also 0-1-8-9?
thanks
thanks
it was originally 1-8-0-9 thats how kess and pcmflash read
swappoed over to 256k 0-1-8-9
- FORD FOCUS MK1 origine_256k.bin
- (256 KiB) Downloaded 564 times
1997 PUMA 1.4 PEST
2001 PUMA 1.6 CHCA
thanks i will try i way you
1997 PUMA 1.4 PEST
2001 PUMA 1.6 CHCA
Is not working, dashboard without display and no communication with diagnostic
I can't be of any help then unless you have a quarterhorse to read the ecu out.
1997 PUMA 1.4 PEST
2001 PUMA 1.6 CHCA
i will buy it .
quaterhorse read full? and sort file of 256KO?
yep its in the getting started write up
1997 PUMA 1.4 PEST
2001 PUMA 1.6 CHCA
Hi,
i have receive the QH setup as describe in getting started.
read the pcm by 2 method on car and on table (i have homemade harness for check pcm without car)
here the 2 bin read, they are the same but no bank order (FF FA 27 FE,...)
if you see what cause this.
thanks
thanks
- ON TABLE TEST PAIL QH.bin
- (256 KiB) Downloaded 539 times
- on car TEST PAIL QH.bin
- (256 KiB) Downloaded 574 times
both reads are the same so thats promising
Doesn't look like any american code I've ever seen.
