[solved] convert 224K to 256K
therocks
Vehicle Information: x3 1997/2000 PUMA 1.7 MUFF / TAPE / DUDE
1997 PUMA 1.4 PEST
2001 PUMA 1.6 CHCA
MONDEO MK3 ST220 6BDB
MONDEO MK3 DURATEC25 1RRC
Unread post by therocks »
Hello,
someone can help me to convert this file, read with kess so 224K bank 1 8 0 9 need to convert to 256k bank 0 1 8 9 for my F3V2
thanks in advance
therocks
1997 PUMA 1.4 PEST
2001 PUMA 1.6 CHCA
Re: convert 224K to 256K
i have make this but cars doesn't start and dashboard have no display and no communication with ecu in diagnostic
ORI FOCUS MK1 256KO.bin
(256 KiB) Downloaded 1087 times
thanks
the detailed step by step process is in the disassembly write up
http://www.efidynotuning.com/dis.htm
therocks
1997 PUMA 1.4 PEST
2001 PUMA 1.6 CHCA
add null filler infront each bank 0x8192 bytes at
0, 10000, 20000, 30000
add 65,536 at 0x000000
cut 0x30000 to 3ffff
paste at 0x0
banks are now ordered 0-1-8-9
clear all null filler by setting it to 0xff
when you say add 65,536, you mean add 65536 bytes at 0x000000?
yes
therocks
1997 PUMA 1.4 PEST
2001 PUMA 1.6 CHCA
If i had 65536 bytes the file is 320ko not 256ko
its supposed to be
therocks
1997 PUMA 1.4 PEST
2001 PUMA 1.6 CHCA
don't understand ^^, file for F3V2 will be 256ko not 320ko?
therocks
1997 PUMA 1.4 PEST
2001 PUMA 1.6 CHCA
if i follow the step without put the 65536 bytes at 0x000000 the file is 256ko. but i see something wrong in the file the vid block when i cut 0x30000 to 3ffff and paste at 0x0, the vid block normally will be at 3FF06 move to 0FF06. maybe something wrong with that
hows that possible if your deleting 65536 when you cut 30000 to 3fffff ?
