I've been playing around with Ghidra, similar disassembly to IDA.
I've created the 8061 processor from the 8096 processor. Works well, took a few days to get 100% disassemble my bin.
This would not have been possible without the help of this forum (decipha) and the excellent work of SAD.
The disassembly is a bit of a manual process, and allows you to define different areas of RAM(SFR, General, etc.) and ROM.
The usefulness of this tool is that it shows you C code style disassembly, graphical flow of code, and references to and from routines, and much much more. Actual debugging (like IDA) is not yet possible, but maybe soon. There are many other features, like adding parameters to functions, and setting return values. With memory mapped out, you can set/clear registers, so you can see how the values are used in different parts of the code.
Below is a screen shot, showing the code browser, graph window, register window:
Download image here:
