"MPAL5B3 — strategy ID for 2000 Expedition 5.4L, need XDF/base bin (rear O2 delete)"
vbfences
- Vehicle Information: 2000 Ford Expedition, 5.4L 2V. VIN: 1FMPU18L0YLA13182. PCM part# YL1F-12A650-BC, Strategy MPAL5B3, Hardware MLC-496/MLC-496A. Rear O2 sensors removed (headers/CAI, cats deleted), throwing P0136/P0141/P0156/P0161. Transmission not yet confirmed — 4R70W or 4R100. 4" cold air intake, shory headers, tire size 285/45r22
2000 Ford Expedition, 5.4L 2V. VIN: 1FMPU18L0YLA13182. PCM part# YL1F-12A650-BC, Strategy MPAL5B3, Hardware MLC-496/MLC-496A. Transmission: 4R100. Rear O2 sensors removed (headers/CAI, cats deleted), throwing P0136/P0141/P0156/P0161. 4" cold air intake, [long tube?] headers, tire size 285/45r22.
034v
Re: "MPAL5B3 — strategy ID for 2000 Expedition 5.4L, need XDF/base bin (rear O2 delete)"
Give it a shot. Believe that is a Premium Member XDF but here is a VIN and PATS editable XDF along with the BIN.
NOTE: XDF might not be the exact addressing so edit what you need. If you read your ECU's 256k binary, those addresses will be at the end.
Read your PATS code, edit whatever you need,
- ZUT2_o2-delay-rear-o2-off.bin
- (256 KiB) Downloaded 133 times
- MPAL5_END.xdf
- (9.06 KiB) Downloaded 148 times
