Lots of changes and same problems hahah
All 89-95 Supercoupes, GURE, GSALC, GSALI, CZAW0
BKB
Vehicle Information: 1994 mustang with a 1994 Thunderbird 3.8 SC motor and Camaro Tremac TR6060 trans. CZAWO with siemens 80s, 90mm tb and slot maf, long tubes and Mac pro-chamber. 15psi 12%OD
400rwhp 450tq
Re: Lots of changes and same problems hahah
Unread post by BKB »
Definity Struggling a bit, a 30 second task is taking me an hour.
Car seems much smoother and idle vacuum went from 10 to 12.
cold start.xdl
(221.24 KiB) Downloaded 26 times
hot idle & drive.xdl
(508.8 KiB) Downloaded 26 times
warm start.xdl
(159.02 KiB) Downloaded 16 times
Your mil is on and your cam sensor is not syncing. That's why your injector timing isn't cooperating.
The throttle stop is a touch too far closed, go ahead and open it about 1/8th of a turn to give her a touch more air to idle properly. That's causing spark to go to MBT at idle and on decel just to prevent a hard stall giving you no torque reserve.
This should make her a ton happier. Looks like your o2 is getting saturated as well, seems to be switching well past stoich. Make sure your not burning any oil.
Load this in and shoot back another step 1.
NOTES
1770 rpm , 60 load , 90 perload - went in to OL FROM FN337
1900 rpm dashpot pegged .8 - needs more
30 load needs 15% more transient enrichment
15 load cut in half
150 imaf on down is > 1.33 corr
.18 dashpot allow closed loop idle
barely decay from .2 to .1 then decay faster
decay faster over .5 dashpot
idle spark needs to be lower
1300 rpm+ dashpot min clip .5
dfso min rpm +700
idle spark 24 needs to be 12
psibrn and psibrm
spkctl, dasctl
iscmultiplier- 60 deg fire off, kick up significantly, us_sw .1, min sw 8, cold delay 240, warm delay 180, hot delay 60, enrichment 80 @ 80 - all gone
BKB_260516a2.bin
(56 KiB) Downloaded 21 times
BKB
400rwhp 450tq
mil turned on when I loaded the tune. I bet I haven't seen that thing lit in 15 years, Will look into it. Idle screw in 1/8 turn. Tip in is pig rich
test1.xdl
(537.27 KiB) Downloaded 28 times
Your o2 sensors are cross scavenging, at 212 sec in the log both hego's split opposite directions. I disabled hego 2 should be all good now.
How is your canister purge hooked up ? Your idle fuel is swinging 60%. Something is majorly causing some inconsistencies, I'm thinking it may just be the o2's swapping back and forth between control of bank. Wouldn't hurt to make sure your fuel pressure is stable and your fuel pressure regulator diaphragm isn't ruptured by checking the vac line.
All this is rather useless though until you get your cam sensor fixed. Without going in to sequential fire your fueling is going to be inconsistent.
This should at least make it easier for you to get it situated.
Also, might as well get the wideband 5v output wired in to the egr input so tunerpro automatically logs it and populates your fuel error.
details- http://www.efidynotuning.com/config.htm
BKB_260516a3.bin
(56 KiB) Downloaded 20 times
BKB
400rwhp 450tq
Tuner pro have any kind of OBD diagnostic? I remembered I never hooked up the OND2 port when I wired in the SC ECU. I never had a check engine light so never bothered. If I have a cam sensor issue shouldn’t it crank several rotations then fire. I notice no change in starting.
no it doesnt
there is no obd2 with the sc ecu, gotta do the old paper clip counting flashes
no, cranking isnt sequential its batch, its pose to switch to sequential once it runs up but yours cant find cyl 1 sync
youll see red sync fail on the dash while logging
BKB
400rwhp 450tq
FPR vacuum line dry, 42psi steady.
Replaced cam sensor with known OEM 30k mile unit. No MIL with BE but MIL with TunerPro, Will need to check wiring.
Will need to wire in WB to EGR, never had to do that before.
Purge is intact and hoses are solid with no leaks. Plumbed into PVC system like OEM but I do have a aftermarket PCV M/E Wagner.
Way back in the EEC Tuner days I would see my narrow bands make one bank go lean and the other rich till she would barley run. Ran OL at idle for ever, headers and exhaust never changed so no idea if it the Mac Pro Chamber.
Tip in is still rich at fast rates and lean at slow tps rates.
test3.xdl
(1.04 MiB) Downloaded 29 times
Its always best to start the log before you start the engine so its all captured and you can see how the engine is trending.
This should have her about as good as she gets for now. Definitely need to get the wideband plumbed in to see whats going on transient wise and for wot. The cam needs to sync in order to get the fueling more consistent. Let me know what the codes are she's throwing and shoot back a vehicle info sheet when you can.
BKB_260516a4.bin
(56 KiB) Downloaded 22 times
BKB
400rwhp 450tq
WB LC-1 wired in and configured 5V - 1.523
0V- - .500
scoped cam signal at ECU and it looked great with low noise. Pulled #1 plug on compression and confirmed TDC matches TDC on dampener. Mover ATDC to the mark I made going off the OEM dampener and checked alignment and the tool fell right on. Now no MIL, will keep and eye on this
I’m using an old netbook and it seems to struggle with tuner pro. It crashes sometimes after saving a datalog, will need to look into upgrading.
test4.xdl
(935.09 KiB) Downloaded 34 times
For the amount of power your engine is making (42% more than stock n/a per cylinder) it sure does not want anywhere near the amount of transient fuel most engine would that are making ~33hp per cylinder.
Odd, in any case I cut it back significantly. Hopefully it tames it a bit.
The cam is still not syncing, the red sync_fail on the dashboard is to let you know its batch firing. It won't set a fault or a check engine light for the cam not syncing only if the cam sensor fails.
Are you sure the engine is at 26 degrees and the inverted U is at the middle of the tang on the cam sensor ?
In any case you can't begin tuning it until you get the cam sync'd otherwise your fueling is going to be inconsistent.
BKB_260516a6.bin
(56 KiB) Downloaded 7 times
