strategy swapping
tufgriz
Vehicle Information: 1993 4.0 Ranger xl Currently stock RAT1
1989 mustang gt running Megasquirt HCI 302 swapped back to a9l
strategy swapping
Post by tufgriz »
So from my understanding it is possible to tune something like the 8ld with a a9l strategy when using a quarterhorse. Would that still apply if I burned a chip when done or would I still have to have the quarterhorse connected to work right?
Re: strategy swapping
Post by red5.0fogger »
From the homepage write up it looks do-able. You tune with the QH then burn that file to a chip that is left in the ecu. Frees up the QH for something else.
F3 chip is needed
tufgriz
Post by tufgriz »
Does it have to be a f3 or could it be a ti chip?
auscob07
Post by auscob07 »
tufgriz
I run A9L/A9L2 on a 8LD ECU but only with the QH. Haven’t burned a chip as yet. Only thing that the 8LD is limited by is fan control. Apparently the hardware does not exist in the 8LD to run fans.
Post by wwhite »
tufgriz wrote: 2025 Sep 13, 00:54 Does it have to be a f3 or could it be a ti chip?
You can use TI chip. I have a couple, haven't had the time to burn.
There is a thread here somewhere that discusses how to. I think memory mapping is a bit different, and burn2 does work.
