Mustang 2013 need to get back to stock
Re: Mustang 2013 need to get back to stock
Post by decipha »
cool, snap a photo of the ecu tag so I know which stock file is supposed to be on it. Post back your SN for your xcal as well when you get it.
Tanataur
Vehicle Information: Mustang 2013 manuel transmission with track pack.
No hardware modification, just a custom tune
Post by Tanataur »
Ok, last question, is there any risk ?
Post by decipha »
risk? of what?
Tanataur
Post by Tanataur »
Bricking the pcm
Post by decipha »
Its not possible to brick the ecu. The xcal could corrupt out during a write and cause issues but unlikely so long as your battery voltage isn't low.
If that's a real concern for you then your only option is to get a mongoose ford pro and pcmflash. Details are on the homepage under the getting started write up.
Tanataur
Post by Tanataur »
Ok i have a new battery. I will go for the x4 and worst cases i will have to buy a mongoose ford pro.
Tanataur
Re: Mustang 2013 need to get back to stocks
Post by Tanataur »
Just to be sure. The calibration files and the operating system has been modified.
The x4 can modified the calibration files in that case ?
Post by decipha »
Not exactly, it cant modify the existing only write a new one.
Tanataur
Post by Tanataur »
My X4 serial i just received : X40310216EDE3
Here is the photo of my ECU in attached file.
Thanks a lot for your help.
Tanataur
Post by Tanataur »
Do you have all the information you need to find the tune ?
