Mustang 2013 need to get back to stock
Re: Mustang 2013 need to get back to stock
cool, snap a photo of the ecu tag so I know which stock file is supposed to be on it. Post back your SN for your xcal as well when you get it.
Tanataur
Vehicle Information: Mustang 2013 manuel transmission with track pack.
No hardware modification, just a custom tune
Unread post by Tanataur »
Ok, last question, is there any risk ?
risk? of what?
Tanataur
Bricking the pcm
Its not possible to brick the ecu. The xcal could corrupt out during a write and cause issues but unlikely so long as your battery voltage isn't low.
If that's a real concern for you then your only option is to get a mongoose ford pro and pcmflash. Details are on the homepage under the getting started write up.
Tanataur
Ok i have a new battery. I will go for the x4 and worst cases i will have to buy a mongoose ford pro.
Tanataur
Re: Mustang 2013 need to get back to stocks
Just to be sure. The calibration files and the operating system has been modified.
The x4 can modified the calibration files in that case ?
Not exactly, it cant modify the existing only write a new one.
Tanataur
My X4 serial i just received : X40310216EDE3
Here is the photo of my ECU in attached file.
Thanks a lot for your help.
Tanataur
Do you have all the information you need to find the tune ?
