Anyone have any idea why the OD light is flashing. I auto swapped my 5 speed Mach 1. It is controlled by a Quick 4 because I didnt have an auto ECU from a Mach 1 (hard to get it seems and pricey too). Im in Canada so the price is even worse for me and I got the Quick 4 used here in Canada.
Are there any parameters I can check in this strategy to disable in case I inadvertently turned something on?
OD light flashing
Canuckstang
- Vehicle Information: 2003 Mustang Mach 1
Forged 4.6 4v. CR 8.5:1, stock heads
Single ON3 70mm turbo
Swapped from TR3650 MT to 4r75W AT with a 3800 stall, triple disc Circle D converter. Controlled by the stock ECU.
3.27 gear
15x x10.5 with 28" MT drag radial
FBGIO
Swapped to PTP2 for auto trans control. Originally RYAK
Tuner Pro RT
Quarterhorse emulator
wbo2-AEM_UEGO (+0.02)
P.B. 1/4 mile 11.22@ 122MPH before being Decipha tuned. Hoping to improve ET and MPH in 2026!
Re: OD light flashing
mach and gt ecus are the same
are you using the mach manual cal?
Canuckstang
3.27 gear
FBGIO
Tuner Pro RT
Yes I have since read that the GT ECU is the same...I'd like to get away from the quick 4 and just control the trans with the ecu. I need the wiring harness too...but thats besides the point...Any year that is preferred over another?
Yes I am using the mach manual cal....AMZ2
