2 step in FGBIO
Canuckstang
- Vehicle Information: 2003 Mustang Mach 1
Forged 4.6 4v. CR 8.5:1, stock heads
Single ON3 70mm turbo
Swapped from TR3650 MT to 4r75W AT with a 3800 stall, triple disc Circle D converter. Controlled by the stock ECU.
3.27 gear
15x x10.5 with 28" MT drag radial
FBGIO
Swapped to PTP2 for auto trans control. Originally RYAK
Tuner Pro RT
Quarterhorse emulator
AEM_UEGO
P.B. 1/4 mile 11.22@ 122MPH before being Decipha tuned. Hoping to improve ET and MPH in 2026!
2 step in FGBIO
Currently tuning my 03 Mach 1 using AMZ2. Does that have the ability to set up a 2 step. I read somewhere that some bins had it and some didn't. Also wondering if it is a spark cut or fuel cut?
Re: 2 step in FGBIO
u can do a fuel cut 2 step, I will prob add an ignition 2 step to my to do list.
Canuckstang
3.27 gear
FBGIO
Tuner Pro RT
AEM_UEGO
Re: 2 step in FGBIO
So, since I'm turbo'd I'm guessing the fuel cut wouldnt be the best option? I think the spark cut would be well received should you decide to do it. I'm currently trying to wire an MSD 2 step and it has been a headache. Come to find out that the 12v trigger doess not work but I can trigger it with the ground trigger instead. Problem is that, there is no ground on the brake pedal switch so if I go that way, I will need to hook a micro switch to the brake pedal. Not too difficult but not as easy as tuning that function in the ECU.
Having a spark cut that can be tuned in the ECU would be great. My one question is how would that be triggered? I'm just trying to set up a 2 step for the track to build a bit of boost at the line. I don't have a Trans Brake so I'm foot braking at the moment. 3800 stall converter.
Re: 2 step in FGBIO
2 step in gufx i wrote for the brake pedal and/or 0 mph with an opytion for the clutch.
Canuckstang
3.27 gear
FBGIO
Tuner Pro RT
AEM_UEGO
Re: 2 step in FGBIO
Thanks Decipha,
triggered by the brake switch is what I would need...
In the meantime, I've done some more research and it might be possible for me to use the cruise deactivation switch that is also on the brake pedal. It's possilbe that it switches to ground. I've got some testing to do to confirm
