What is Everyone using for Chips Now?
rusty_lawrence
WAY1 / SMD-221 / AHAC2
Novi 2000 intercooled S/C
Re: What is Everyone using for Chips Now?
I just ordered a few. A little learning curve on how to pad for the 56k, but it's working. I wish that was more seamless in TP.
galapogos01
- Vehicle Information: Many local Falcons :)
Thanks for your order Rusty!
We also have a 3D printed Clip-In J3 Chip retainer cover that works on all cast case EEC-IV and EEC-V ECUs. STL available on the site if you have a printer.
Cheers, Jason
Just to answer this one, our burner also works with Binary Editor, and we sell an edge interconnect board to allow programming via the edge connector instead of the ribbon. This works with F3 chips but not F3v2.
Cheers, Jason
I ordered 5 or ten last year. Clip on thing sounds interesting, have a direct link?
A few months back I bought up all the old sniper stock which is actually made by moates. I have several boxes of chips as well as some jaybird pros and quite a few quarterhorses too. Info is on the homepage if you click on the moates logo it'll take you straight to the link.
viewtopic.php?t=995
viewtopic.php?t=995
galapogos01
rusty_lawrence
question... I can take my 56k tune file, pad it to 256k, and program a TI-J3 chip using the moates jaybird with no problem (0x00 00000 to 0x00 3FFFF for chip and buffer). When I tried to use the jaybird to program the TI-J3 with a normal/non-padded 56k tune file using the jaybird single bank addressing (Chip 0x00 32000 to 0x00 3FFFF Buffer 0x00 0000 to 0x00 0DFFF) it wont take. The SCT and f3v2 take it with no problem. Does the TI-J3 chip just not accept a 56k tune? or is there a different setting to use for a 56k with the jaybird?
galapogos01
Yes, this will work fine. Make sure you erase first when using a Jaybird.rusty_lawrence wrote: ↑2024 Sep 13, 20:02 question... I can take my 56k tune file, pad it to 256k, and program a TI-J3 chip using the moates jaybird with no problem (0x00 00000 to 0x00 3FFFF for chip and buffer).
rusty_lawrence
I can’t get it to work on a 56k single bank tune without padding it. I don’t get it.
rusty_lawrence
got it to work on a 56k single bank tune without padding using the jaybird. Had the use the following for the addressing.
(Chip 0x00 22000 to 0x00 2FFFF Buffer 0x00 0000 to 0x00 0DFFF)
That may be a replacement prom on your ecu.
Can you see if the ecu has a replacement eeprom?
Interesting if they did instead use that bank position for default. May have a tune selection on the chip as well?
