EEC V file conversion
Re: EEC V file conversion
@jsa Do I need to join github for it to work? It acts like it wants to download, then doesn't seem to do anything. I don't mean to be any trouble. This should be simple...
ADDED: Windows Defender was blocking it. If it is a public file it Github, you don't have to join to download. I now have it downloaded. When I open it, it looks like an old DOS program sort of. What do I do with it now?
Ok, So I think I got the destination register thing, I was looking in the code for the value that the code was loading into a register. Now I get that the register is not in the code at all, It is in the hardware and looking for the value that is loaded into a register in the software is not going to get me anywhere because it isn't there at all. Still very confused on how to determine what the subroutine is actually doing though, Are the subroutines all the same throughout all of the EEC IV and EEC V computers? example: subroutine sub_021b6 in the RZAZA code seems to be a PATS subroutine(if I am reading correctly), does that mean that in all code it will be a PATS subroutine? and how far does PATS actually go? ie: does it have more than 1 subroutine? thanks again for all the help. Still reading and trying to make sense of the A/D routines in the code. I am using Deciphas def file for RZAZA and the stock bin he posted for PDN0 that i disassembled with SAD to try and get a feel for where the definition file is pointing to in the LST and MSG files, Is this a good way to learn or is that leading me in the wrong direction?
EDIT: So I think I am heading in the wrong direction here...I can not seem to find many other functions by searching for the hex address listed in the def file in the lst or msg files. So I guess it is back to the drawing board on that one.
It's a windows command line executable. There is a GUI front end for it on github.
I just drag and drop the bin on the sad exe, it will then do a disassembly run placing a lst and msg file in the same folder as the bin.
R34 is the destination register in the code line above.
Yes a register is a hardware address for memory within the microprocessor. Certain register and ram addresses will be payloads for logging. We'll get to that.
I'm not familiar with PATS in later bins nor do I have RZASA at hand right now. The address will often be different, but the subroutine will be common to many bins.
Many are, some have minor differences, others are the result of new features being added to newer strategies.BOOSTEDEVERYTHING wrote: ↑2023 Oct 07, 23:09 Are the subroutines all the same throughout all of the EEC IV and EEC V computers?
I'll post some more tomorrow on the a/d.Still reading and trying to make sense of the A/D routines in the code
Yes it will help you. See if you can find iACT and iECT in the xdf then find it in lst.I am using Deciphas def file for RZAZA and the stock bin he posted for PDN0 that i disassembled with SAD to try and get a feel for where the definition file is pointing to in the LST and MSG files, Is this a good way to learn or is that leading me in the wrong direction?
Here is what I see after opening SAD
I can't seem to find either one, I'm not sure what i am doing wrong. IECT may just not be present because it uses a CHT sensor instead, but I can't seem to be able to find the MAF transfer function either, at least not with anything defined in the xdf, It is weird because his def can not be wrong seeing as how he uses it regularly. Some addresses seem wrong as well. Maybe because I am using one of his bins and not a stock read? I am using his xdf file and the PDN0 maurader file with 4r70w bin file.
Values loaded by immediate address mode are often addresses...but how to tell...BOOSTEDEVERYTHING wrote: ↑2023 Oct 04, 12:10Code: Select all
Sub_8316e: 8316e: a1,8a,6d,34 ldw R34,6d8a R34 = 6d8a;
83173: 56,34,00,04 ad3b R4,R0,[R34] AD_Cmd = [R34];Read about the address mode in the manuals.
56 Is the opcode
R34 Contains the value 6d8a. The square brackets around R34 for an indirect address mode mean that ad3b will get the byte of data at address 6d8a.
R0 Contains the value 0x00.
R4 Is a special function register, specifically the AD_Cmd special function register.
The operation reads the byte from 6d8a, adds it to the byte 0x00 and writes it to the AD_Cmd special function register.
Read about memory expansion from Page 6-57 of the software manual. Memory Expansion is how multibank bins are implemented.
Read about the location of the data bank in particular.
The processor is automatically prefixing the data bank number to the address 6d8a to give 16d8a.
From your LST.
0e906: b1,11,11 ldb R11,11 BANK_Select = 11;
R11 is special function register 11, the memory bank select register.
11 is the high and low nibble written to R11, so both stack and data use bank one.
This operation loads the memory bank select function register with the stack and data bank numbers.
So we know 6d8a is being used as an address because of the indirect address mode operation at line 83173.
We also know it is in Bank 1.
Add each of these lines individually to your DIR, rerun SAD, then look at those addresses to see what has happened.
Add both together in your DIR, rerun SAD, then post up the results from LST.
STR 16D8A 16DB7 $Q1 :Y :WN #
STR 16DB8 16DD0 $Q1 :Y :WN #
More later.
@jsa I got it to download properly and it accepted the bin file. I hope you guys don't mind me following along. It is helping me see how this is all laid out.
