Escort P2D Put in a 4 Cylinder /w different firing order
P-Vilefort
- Vehicle Information: 1972 VOLKSWAGEN SUPPER BEETLE 4 CYLINDER BOXER ENGINE 1600CC (1.6l) CONVERTING TO FORD EEC-IV EDIS & SEFI. P2D COMPUTER CODE FOR A 1.9L SOHC FORD ESCORT FEDERAL EMISSIONS, MAF & SEFI, 19LB.HR INJECTORS.
I HAVE INCORPORATED AS MANY SENSORS AS I COULD USING FORD COMPONENETS. CANNOT INCORPORATE EGR, PCV BECAUSE THESE NEVER EXISTED ON THIS ENGINE.
Working on completing the crank trigger, cam trigger (cam position sensor for the fuel injection). Need to solve firing since the VW is different from the Ford firing order. Firing order on the VW boxer is 1-4-3-2. Number 1 cylinder is on right front corner, then behind it is number 2. Across from #1 is #3 and behind #3 is #4. When #1 is on ignition #3 is on its exhaust stroke. When #4 is on its ignition #2 is exhausting. The VW is basically a 2 bank 4 cylinder engine.
I was planning on installing two O2 sensors near the exit of #2 and #4 since this is where #1 and #4 join the exhaust system. So the O2 sensors would measure the right bank and left bank individually. There is no cat on this car either. They were not required in 1972 and since this is a 50 year old car it is not subject to the emissions standards. The Ford system is similar in operation to what was used on the Mexican VW Beetles, with injectors aimed at the intake valves and a throttle body. Air was measured using a vane system (Bosch Motronic). This system is not good at correcting to changes like the Ford MAF is designed to do.
First thing I did when considering this was to get Charles Probst's book on the Ford EEC and EFI book. Then after reading it from cover to cover, I began searching the internet. Found some good things and also a lot of BS. Found Mr. Ponthieux's postings and that led me here. I think Michael can give me a clue on how to correct for the firing order without having to buy a $450 chip. There has to be a way to modify for firing order without resorting to this.
Oh, my background is in Mechanical Engineering, Thermodynamics and Fluid Mechanics, earned when computers were still using punch cards. The personal computer didn't become readily available until about 1985-86. Potable computers were as big as the biggest carry-on luggage.
I joined this forum hoping I could get a solution to my problem of changing the firing order that is built into the Ford EEC-IV that I bought and that I will use to operate my '72 VW Super Beetle.
I was looking for some fuel injection ideas when I came across a discussion where the EDIS module was used in conjunction with a Megasquirt module to get rid of the distributor. I got to thinking after looking at the cost of the Megasquirt that maybe the Ford EEC-IV could be adapted to another 4 cylinder engine. If the EEC got the correct inputs it wouldn't know whether it was hooked up to an Escort 1.9L or a VW 1.6L soon to be a 2.1L. So I began a hunt for literature. I found Charles Probst's book and bought it. I couldn't find anything for the fifth version of the EEC that had as much information as Probst's book. I did find out that the EDIS module had been incorporated in the -V version but that was all and I needed to know more. I also read that it could be reflashed, i.e. essentially reprogrammed.
I figured that the Ford unit would be the way to go and I could learn a load of useful information in the process. If I had only known about the Ford system I could have used it to fuel inject my 1951 Studebaker Champion when I implanted it with a turbocharged Studebaker 259 V-8 with a pressurized carburetor. Fuel injection would have solved a whole lot of problems and would have been easier to set up when the inlet was pressurized.
So Mr. Michael Decipha Ponthieux, how can I solve the firing order problem to get sequential fuel injection? Is it really as simple as rearranging the pins to match my engines firing order? Changing the pins will not create a lean condition on one "bank" when compared to the opposite bank? Air cooled engines do not like lean conditions; pistons can melt easily and the aluminum cylinder heads can crack if there is any preignition with lean burning. My engine is flat but it is similar to a Ford V-4 industrial engine that was used in the Capri and the Saab 96 in the 1970s.
Re: Escort P2D Put in a 4 Cylinder /w different firing order
4 cylinders do not have banks just 1 bank
yep as simple as putting the wiring in the correct order
running lean is based on how you tune it
P-Vilefort
Yes, an inline 4 cylinder engine doesn't have banks but the layout of a boxer engine has 2 cylinders on the right side and 2 cylinders on the left. They do resemble banks as in a 'V' or 'W' configuration.
I have read instructions for arranging the spark/coil wires that would be used with wasted spark utilizing the EIDS module on the VW 4-cylinder boxer engine so I understand how rearranging the pins could create a new firing order that the ECU would not know about.
I have an article about rearranging the pins to effectively change the firing order if you are using an ECU that was originally used on a Ford HO V-8 and the concern there is the readings of the Heated Oxygen Sensors on the right versus the left bank where the pins from the normal V-8 firing order were rearranged and the statement was that doing this will create a cascading effect of lowering the fuel to the cylinders with the rearranged pins. There is no explanation how this can occur, though.
Here is the link to the argument for not changing the pins. I am not saying you are wrong but if you haven't seen this you might find it interesting. This addresses a V-8 engine configuration. In my case if I used only one HEGO where the exhaust from all cylinders comes together maybe I will not have this problem.
http://www.grandmarq.net/oldfuelinjection/page92.html
How about I cut and paste it here.
"Injector Firing Order
There are 2 ways to "correctly" fix a computers' mismatched firing order:
1. The best option is to change to a HO camshaft to match the computer. (not applicable)
2. Or you can reprogram the computer to match the cam firing order. (reprogramming with a chip)
"Firing order does not effect spark at the plugs because that is still determined by what order you put the plug wires on the distributor cap. But if you have a sequential fire fuel injection computer, then the computer program opens the injectors in the same order as the camshaft timing. This can cause issues when running a “High-Output” computer with an older camshaft. If you leave the injectors in the HO order you might notice a slight effect on idle quality. There are no effects once the engine speed picks up because the injectors open so fast."
"Other people with mismatched computers swap the injector pins at the computer plug. This causes more problems than it solves."
"An example of how the computer deals with mixed up injectors:
1. The R O2 sensor sends a rich signal to the computer.
2. The computer will then shorten the pulse width to Right side of the engine. But two of those injectors have been MOVED to the Left side of the engine!
3. Because 2 of the injectors that have been directed to minimize the injector pulse are now on the other side of the engine, this causes the left side of the engine to run lean.
4. So now the L O2 will send the lean signal to the computer.
5. The computer will then lengthen the pulse width to Left side of the engine. But two of those injectors have been MOVED to the Right side of the engine!
6. So now the R O2 sends another rich signal to the computer.
7. Cycle repeats, each time getting worse."
"You end up with 1, 2, 5 & 7 running 25% rich, and 3, 4, 6 & 8 running 25% lean!
Therefore it is strongly discouraged to mix around the fuel injectors." (See V-8 GIF illustration)
The VW firing order is 1-4-3-2 and the Ford is 1-3-4-2. Would it be better to move the pins around or modify the programming? Will I still need a cam timing device for the sequential injection? There are ones available for the VW. I am checking on a vehicle speed sensor. I may adapt one from an ABS equipped vehicle and put it on one of the transmission drive shafts constant velocity joints at the transmission. Please supply advise.
Some additional information. My EEC-IV is a P2D I bought from RockAuto/Cardone 78-5144 for a '92 Ford Escort 1.9L SOHC 4-cylinder engine, MAF SEFI. I am using most all of the Ford sensor except those that Volkswagen never had on this engine such as EGR and PCV. I have also read thorough all of the information that you have posted online. I am in the process of replacing motor transmission mounts since they are 50 years old. I think I have all the sensors I need except for the throttle body, intake air temp, idle air solenoid, throttle position sensor. I am working out whether to make my manifolds with injector bungs or to purchase some that were used on the Mexican Beetles ($$$$). In the past I have always constructed my own modifications and since I need the intake manifold I was going to make it and the portions that connect to the head and weld on injector bungs. Initially I will be using the Escort 19#/hr. injectors. I will be increase the VW engine to 2.1L with increased CR of 8.5:1 with larger bore and stroke. Maximum RPM will be 5500. I am not going racing. I want fuel injection and distributorless ignition for drivability primarily. Both will be advantageous for street use too. I also have the Power Module. I don't yet have a diagram of the guts but I assume that the sensor voltage regulator is a zenier diode to clamp the voltage at 5V. I have a wiring loom for an Escort, a new EDIS along with the proper 12 pin connector and some of the wires. Thank you!
cant happen on a 4 cyl no worries
mistake buying that ecu you should have gone to eec v with internal edis
vss is nice but not required
yes a cam sensor should be installled for sequential injection but not required
P-Vilefort
Can you briefly explain your last statement that a cam sensor should be installed for SEFI but it is not required? I saw in the Probst Ford Fuel Injection book that there is a cam sensor on the Escort 1.9L 4-cylinder but there is not much of any explanation how it functions i.e. what it does that the crankshaft position sensor cannot do.
I have seen that statement about making the mistake purchasing the EEC-IV other places. The reason I purchased the EEC-IV instead of the fifth version is that I could not find the type of information that is in the Probst book on the EEC-V. I also saw that the later EEC moved the EDIS-4, -6 and -8 into the computer case. Connector went from 60 pins to 104 pins.
Is the barometric pressure sensor inside the EEC-IV computer case? I read in the Probst book that it was moved to the computer housing. I have also found out that I could have used the EEC for a V-8 engine instead of the one for the 4-cylinder. I thought that it might turn out that I could use either the 4 cylinder or the 8 cylinder EEC.
Where can I find technical reading material on either computer?
Is there any information on the P2D programming that you can share or where I can find the information? The P2D cost me $85 including the shipping.
I appreciate your input.
sailorbob
An eec-iv is perfectly fine for your application. The main issue is the finding DIY tuning hardware (now Moates have closed) and a definition to suit the strategy your ECU uses. For the latter it is best to find what strategies are supported and then select an ECU that uses one of those.
The different firing order of the VW and the Ford engines is not a problem, just rearrange the injectors and HT leads to suit.
Lots of reading material on;
https://github.com/OpenEEC-Project
P-Vilefort
What do you mean by "strategy"?
sailorbob
The strategy is essentially the program the ECU runs. It can be used on just a single type of vehicle or several dozen.
P-Vilefort
Do you have a list of what the different strategies are and a pinout list or diagram for the P2D?
When I purchased the P2D, it was for cars or engines that were to meet the Federal emission requirements in all states but California, and I believe it was to be used on naturally aspirated engines. It was designed to be used with MAF and SFI (ESFI). I expect that the pinout would be the same for a number of engines that were used in the Escort but not any of the Nissan or Mazda electronic systems in the 1991 to 1993 years of production. This computer may have had a different strategy series when it was originally made and the information from Cardone indicated it was checked and repaired as necessary and reprogrammed. That makes me wonder if the P2D is the "after reprogramming" designation. I have seen lists of the strategy numbers used and P2D is not in any list I have seen.
Do you have any clues or information as to what a P2D is in comparison to other 1.9L 4-cyliner Ford CVH engine computers?
I answered my previous question regarding the cam sensor trigger. There is an extra lobe on the camshaft that is simply a trigger for the sensor. The lobe is much smaller in thickness than the lobes that drive the followers and looks much like the lobes found on flat head engine cams from the 1940s through the late 1950s when the engines were phased out and replaced with OHVs.
The two VW FI suppliers I know about that are in America both had cam position synchronizers but neither is offering any now. I purchased a new manufactured distributor for @$30 that I am going to use to make a cam position device using the same kind of sensor that is used with most of the crankshaft sensors. The Dub Shop uses a VSS Hall effect sensor (Ford Probe or Mazda Miata) that is very short and I am going to use the same type in the body of the new distributor and a single tooth over the distributor cam (starting with a multiple tooth reluctor). This will produce a signal that the EEC-IV can use. The signal should be identical to the sensor used on the 1.9L engine.
Will I get the same signal for the cam position if I use a magnetic pickup?
Thanks for your insights
Paul Villforth
Paul Villforth
