351w 36-1 alignment
351w 36-1 alignment
I have the 28oz balancer that requires the explorer wheel to be pressed on.
I am using an aftermarket timing cover that has the VR sensor fixed mount.
Question is, if I press on the wheel and am out by one degree, will that mater, does it have to be perfect, and can it be adjusted after in the tune?
Re: 351w 36-1 alignment
yep it matters
no it cant
AcesArneson
Vehicle Information: 1973 Mustang Convertible
Unread post by AcesArneson »
Can't you adjust the sensor by one degree? Is the sensor on sliding bracket?
AcesArneson wrote: ↑2024 Feb 29, 19:19 Can't you adjust the sensor by one degree? Is the sensor on sliding bracket?
No, it’s fixed, see pic, ignore red arrow:
AcesArneson
Sorry wwhite, I have no idea. Mine is on the outside.
So, with the VR sensor mounted, fixed, crank at TDC, the wheel need to be mounted on balancer at where the VR is directly over the whole tooth, 5 teeth before the missing tooth? Is that correct.
Of course timing pointer would also be at 0 degrees on balancer.
First time doing this setup, hope my question makes sense.
wwhite's picture looks like the Explorer timing chain & gears cover.
ATPCR wrote: ↑2024 Mar 03, 12:14 wwhite's picture looks like the Explorer timing chain & gears cover.
Correct, I have a brand new one.
Using a 28oz balancer that had the 4 point star(misfire ring), and 36-1 wheel from an explorer 50oz balancer.
I’ve pressed off both rings, ready to press on 36-1 wheel onto 28oz balancer, just needs to be perfectly aligned as there will be no adjustment after wards.
If I were at work, I would get you a picture of what my Explorer,Mountaineer balancerdamper,36-1 ring looks like like at TDC. I wont be back there until Monday morning ~ 9:30 central time USA. Do you have the slick water pump pulley that I think is unique to the 96-01 Explorer front engine dress?
