Page 1 of 2
Couple questions about A1C tune
Posted: 2024 Feb 04, 10:27
by David Claflin
my neighbor finally relented and sold me his 91 F-150 Nite, 78K original miles.
Plan to do some minor mods, exhaust, head work, small cam, along with a tune. My questions are:
Will the ZD2 work on an A1C processor, or is there an actual ZD2 processor?
Is there a way to convert the XDF and bin to work with Binary Editor?
Any recommendations what trucks to look for in getting parts for mass air conversion on this. From what I understand 94-95 as long as it has an E4OD in it
Thanks!!
Re: Couple questions about A1C tune
Posted: 2024 Feb 04, 10:43
ZD2 is A1C its the same strategy
Yeah someone could make a def for BE using tunerpro as the basis. Thats actually how BE started as BE used to have a tunepro xdf importer back in the day.
If your doing all that work to create a BE file why would you do a mass air conversion?
Posted: 2024 Feb 04, 11:57
by David Claflin
Mass air would be last resort, figured there might be a file for those in BE. If batch fire works OK than can leave it SD, and just work with that.
Posted: 2024 Feb 18, 15:19
by David Claflin
Decipha, are you the owner of the files in here:
viewtopic.php?t=64
Was going to have Clint Garrity convert them for me, but he said they're encrypted and he'd need a key from the owner.
Posted: 2024 Feb 19, 11:51
by efloth
Posted: 2024 Feb 19, 15:39
correct the password to all my xdf's are DONOTEDIT
Only reason I put a password on them is to prevent thousands of minute and incomplete copies from being out in the wild. Its much better for everyone if someone posts an error they find so everyone has correct info when they get the next update.
Posted: 2024 Feb 19, 19:04
by David Claflin
OK, thank you, I presume it's OK to pass that along to Clint?
Posted: 2024 Feb 20, 11:03
yep no prob, he should be able to take care of you
Posted: 2024 Feb 21, 05:24
by David Claflin
N/M
Posted: 2024 Sep 11, 18:41
by David Claflin
Im getting an error when I try to open the XDF with tuner pro RT. says the file was created with new version of the program. I downloaded the newest version of Tunerpro RT from the Tuner pro website...
