2 step setup
D3fault
- Vehicle Information: 1998 Mustang 3.8 manual. base. HHU1 catch code. basic bolt on's: longtube headers, cold air intake,full straight piped side exhaust, 3.73 rear end gears, stage 1 clutch, moates quarterhorse chip, under-drive pulley kit. short throw shifter, poly bushings everywhere.
2 step setup
hi. i am trying to setup my neutral switch launch control and having some issues. i went into my tune and selected the correct neutral switch hardware settings and set the rpm to 2500 but when i attempt to use it the car acts like the ecu thinks its always in neutral and wont rev past what i set the 2 step to. could someone take a look and tell me what im doing wrong? thanks
- stock_base_emissions deleted_+3 .80-.50_700rpm-5500rpm.bin
- (256 KiB) Downloaded 1416 times
