Hego Bias / Amplitude
Posted: 2023 Dec 21, 00:15
by DOHCTOR_32V
Trying to make sense of this formula / equation. Would someone please spell it out for me?
Formula:
FOR SMALL BIAS 0 < |BIAS_G/PTPAMP| <= 0.171573 (0.171573 = 3 - SQRT(8))
Equation in my case: (I think)
|-.0840 / .0332| <= 0.171573 (0.171573 = 3 - SQRT(8))
Re: Hego Bias / Amplitude
Posted: 2023 Dec 22, 14:15
by jsa
It means, for a small bias, bias_g/ptpamp is greater than zero and less than or equal 0.171573.
Posted: 2023 Dec 22, 21:37
by DOHCTOR_32V
I have the full CBAZA documentation which includes the info you posted. It does not offer a solution that is understandable like the other two equations directly above and below that equation in the document do. I guess no one else whom has viewed this post understands it because no one has offered an explanation that indicates what the adjustment subtracted from stoich is for a given, negative BIAS_G/PTPAMP.
FOR NO BIAS |BIAS_G/PTPAMP| = 0
The limit cycle has full jumpback on both sides of stoichiometry and uses
symmetric pulsewidth ramp rates.
The limit cycle has a partial jumpback on one side of stoichiometry to
achieve biasing and uses symmetric pulsewidth ramp rates.
FOR LARGE BIAS 0.171573 < |BIAS_G/PTPAMP| <= 0.45
The limit cycle has no jumpback on one side of stoichiometry and uses
asymmetric pulsewidth ramp rates to achieve biasing.
Posted: 2023 Dec 23, 15:14
by jsa
The direction of the bias is controlled by the sign of the bias value. If the bias term is negative, a rich bias is indicated. If the sign of the bias term is positive, a lean bias is indicated.
Posted: 2023 Dec 23, 21:29
by DOHCTOR_32V
Yes, but how much richer or leaner? That statement does not help solve the equation in order to give a final AFR / Lambda number, so a person knows what AFR to expect from the calculations. We can log it for AFR delta, but that still doesn't enable us to validate or use the equation in a meaningful way, if the formula can't be interpreted.
Posted: 2023 Dec 27, 07:04
by red5.0fogger
It just adds or takes away until it switches rich or lean , then the opposite happens. It's minute amounts in a never ending closed loop.
How much it adds or takes away doesn't matter, unless you just want to know.
Posted: 2024 Feb 06, 11:21
Bias is your value from the FN1353 table. 0.084 is not possible as the memory size doesn't permit a number that high. Lets use 0.010 as an example.
Amplitude is from the fn1352 table. 0.0332 isn't possible as the memory size and equation only allows 3 decimals. Lets use 0.033 as an example.
0.010 / 0.033 == 0.303 is our bias/ptpamp
That bias/ptpamp is higher than the max allowed of 0.171572875254 so it gets set to 0.171573 as a max clip.
That value is from your calculator if you simply plug in 3 - 2.82842712474619 == 0.171572875254. All they are doing is notating it there just for reference only.
Posted: 2024 Jun 26, 01:47
by DOHCTOR_32V
Thank you decipha.
