Assuming I have my fuel, load and idle all dialled in, how can I sort out my cold starts. Of course I have read the write up a number of times and know that I am going to need to see a richer mixture for a few minutes (to op temp) and even richer for the first few seconds.
Is it possible to sort this without a wideband? Do the narrowband HEGOs report enough to use the calculated FE% in TPRT while the are completely cold?
Cold Start Enrichment
auscob07
- Vehicle Information: Cobra. Fox 5.0 with 8LD ECU. TW170 Heads and TFS cam. MassFlo (ProM) EFI, 24# injectors.
Re: Cold Start Enrichment
you simply give it more fuel and see if it likes it or not
auscob07
Easy, thanks.
