Unsigned to Signed
Unsigned to Signed
I changed the input to FN810 for delta-n so I don't have to update it each time I change idle rpm and as a bonus it'll chase the rpm adders.
These are the two equations already in the code.
NOTE: //dsdrpm [50] *16 == 800 rpm. rpm [3200] /4 == 800 rpm.
OPTION A
4ddd: 11,18             clrb  R18            R18 = 0;
4ddf: b3,72,e6,19       ldb   R19,[R72+e6]   R19 = DSDRPM;
4de3: 08,02,18          shrw  R18,2          R18 = R18 / 4;
4de6: 48,18,ae,18       sb3w  R18,Rae,R18    R18 = N_RPM - R18;
OPTION B
505a: af,72,e6,30       ldzbw R30,[R72+e6]   temp6l = (uns)DSDRPM;
505e: 09,06,30          shlw  R30,6          temp6l *= 40; // 40 hex== *64 decimal
5061: 48,30,ae,30       sb3w  R30,Rae,R30    temp6l = N_RPM - temp6l;
Option B is what I'm currently using.
Neither of the two options have signed variables so what would be the easiest way to make it roll over and actually be a signed equation?
tvrfan
Re: Unsigned to Signed
Unread post by tvrfan »
I don't see any difference from a look at the changes. What comes next ? (or which bin is it?)
Oh wait.... is DSDRPM signed ? If it is, you should to load it with ldsbw, not ldzbw. ldsbw preserves correct signed value byte->word.
the rest after that could be either - what comes next? the conditional jumps will confirm it....
GUFX
Nothing comes next, it calls out does the error calc and returns for the look up.
DSDRPM is unsigned as its the commanded idle rpm.
5cce: 45,b0,02,f4,32    ad3w  R32,Rf4,2b0    temp7l = 9286;                 // FN810 ISCDC RPM Adder
5cd3: ef,98,44          call  a16e           subr_R34_RPMERROR();           // X Input changed to RPM ERROR decipha 23-11-27
5cd6: ef,33,d9          call  360c           IntWdLU_fu32w_in34w_ou38b();
  subr_R34_RPMERROR:
a16e: af,72,e6,34       ldzbw R34,[R72+e6]   tmp1l = (uns)DSDRPM;
a172: 09,06,34          shlw  R34,6          tmp1l *= 40;
a175: 48,34,ae,34       sb3w  R34,Rae,R34    tmp1l = N_RPM - tmp1l;
a179: f0                ret                  return;
I figured out my problem, I was having a brain fart from having one of my lookups labelled wrong in my directive.
If N_RPM is a lower value than DSDRPM something was preventing r34 from rolling back.
ex: r34== 500 - 800
== -300
It helps when you use the correct lookup.
All good thanks.
