04 Mach 1 5 speed Todd Warren custom cams BBK throttle body
Using tuner pro rt switching from stock manifold to LT cat less X pipe Do i need to tune for long tubes? And how? The egos are further back then stock manifolds.
Thank you for any help you can give me
MB
Headers switch to long tubes
mbsvt1
- Vehicle Information: 1992 Ford Mustang 5.0 LX vert 5 speed summer edition
347 cid
Long tubs 2.5 full Exhaust
Comp Cams extreme energy 282
Re: Headers switch to long tubes
yes you need to kick up the hego delay then use the histogram to dial it in
kick up the CL delay
kick up the o2 sensor duty cycle
then make sure you dont get any cross scavenging with the x. You can tell by the lambses going in far opposite directions while accelerating. If it does then disable hego 2. If it only does it on decel then use LOLOD / FN338 to force open loop on decel.
