04 Mach 1 switching from std to auto.
mbsvt1
Vehicle Information: 1992 Ford Mustang 5.0 LX vert 5 speed summer edition
347 cid
Long tubs 2.5 full Exhaust
Comp Cams extreme energy 282
Unread post by mbsvt1 »
What changes do I make in the tune to run auto trans in a 04 Mach 1 that has a 5 speed?
Ty MB.
Re: 04 Mach 1 switching from std to auto.
youd need to swap to an 03-04 automatic ecu to control the trans the manual ecu physically lacks the hardware
but its as simple as writing the auto tune to it as they are all the same class ecu
mbsvt1
347 cid
So then you can wright the auto tune to the manual trans pcm? Or better to source out and auto trans pcm and tune from there with my QH.
Cougar281
2002 PI 4.6L V8
1999 J-Modded 4R70W
2004 PTP2 PCM
Unread post by Cougar281 »
You could write an auto tune to a manual trans (I assume), but because the manual trans PCM lacks the physical hardware to control the transmission, it won't work (and may set codes). You need to find a PCM from an auto trans vehicle.
mbsvt1
347 cid
Thank you Cougar281 for clearing this up MB
