I see the functions for MAP but since it's not relative to me, I haven't played with those. My friend wants to tune his Speed Density setup tho.
So can I load the A9L2 up for him and tune I gather the Volumetric Efficiency / MAP stuff?
Simple ? - Speed Density works w/ A9L2 Right?
entity-unknown
Re: Simple ? - Speed Density works w/ A9L2 Right?
I think you'd want to use A1C for that
Speed density ecu's are a different hardware class than mass air ecus so no you cannot run the a9l2 cal on it.
Plug in his hardware code in the search box on the supported ecus list and it will let you know if its supported and by what strategy.
http://www.efidynotuning.com/downloads.htm
rusty_lawrence
- Vehicle Information: 1994 F150 Lightning
WAY1 / SMD-221 / AHAC2
Novi 2000 intercooled S/C
i know this is an exception... but... that marine setup i been playing with violates this rule. the marine bin is SD and the automotive bin is MA. So one hardware code EFI-MA39 has oem cals for SD and MA. and definitions out there for both.decipha wrote: ↑2023 Oct 03, 08:07 Speed density ecu's are a different hardware class than mass air ecus so no you cannot run the a9l2 cal on it.
Nothing to do with the topic, sorry, but sharing something cool i learned when playing with it.
Yeah but thats not a production cal its something correctcraft and ford had going on. One of their many side adventures like the manlifts and what not.
entity-unknown
Unfortunately his ECM doesn't have a catch code (cheap reman) but def notable, no A9L2 for him ;)
I'll look more into the A1C and the other BINs to see what will work for him. Thank You!
what year make model is his vehicle ?
